Old 5/25/07, 8:21 PM
Charley L. Bottger's Avatar
Default Sump pump I get all of the good ones
I don't know why I am so lucky
This trash can located in a basement has been in use for a long time the kitchen sink drain from above and the washing machine from the basement is discharging into this fancy sump pump pit the pump then discharges into the main above the grade of the basement
Now I have to decide what I want to write about this mess??????
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 5/26/07, 10:17 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Default Re: Sump pump I get all of the good ones
Are they using a sump pump or a gray water pump? Not that it matters!
It just makes no sense for the kitchen sink to not be connected properly.
Now for the washer, it could have been drained in to a laundry tub with a gray water pump connected to it.
By the way, can I use these photo's in presentations?
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 5/26/07, 10:50 AM
Sure use the Pics any way you would like.
They were using a standard submergable sump pump and had cut the original sink drain line and installed the discharge of the pump back to this line.
The basement originally had a floor drain and a stand pipe for the washer but apparently the floor drain line had become stopped up or collapsed no longer in use
</IMG>
NACHI Member
State License # 130
Old 5/27/07, 12:49 AM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bet that smells nice.
Nothing any stinker than old laundry water.
Old 5/28/07, 11:58 PM
I would think it would stink more if it had Baby Ruths floating in it
NACHI Member
State License # 130
Old 5/29/07, 2:48 AM
W. Michael Chris's Avatar
W. Michael Chris W. Michael Chris is offline
Charley,
"Sump pump I get all of the good ones" . . . maybe you should pass some around . . . and I don't even want to think about the Baby Ruths
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 4:38 PM
Sump Pump Recall jbushart Plumbing Inspections 1 2/15/07 9:50 AM
