Old 10/20/10, 3:03 PM
chiatt chiatt is offline
Default Sump Pump Question
What is the rod on the left of the sump pump pit?
Cathay Hiatt
TasMar Inspections
(816) 260-1903
inspect.myhome@yahoo.com
Adapt and Overcome
It is true of the nation, as of the individual, that the greatest doer must also be a great dreamer.”
—Theodore Roosevelt
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/20/10, 4:12 PM
John Harrison's Avatar
John Harrison John Harrison is offline
Default Re: Sump Pump Question
where did the lines off of it lead to?
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 10/20/10, 4:48 PM
Could this be some attempt at an earthen grounding rod? The lines go under the concrete. This sump is located in a sub basement with electric meter located outside wall pump located near. Panel in basement in adjacent area
Cathay Hiatt
TasMar Inspections
(816) 260-1903
Adapt and Overcome
—Theodore Roosevelt
Old 10/21/10, 10:38 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Could be a water alarm. I have a one in my sump put, what emits a signal when water reaches the top, indicating that either the pump failed or cannot keep up with water entering the pit.
I also see no float valve. This device sould signal something to shut power to the pump; like a pressure switch of some type. Conductors are too small to be any type of meaningful ground rod, IMO
Old 10/21/10, 12:28 PM
Thanks so much Joe. I have been really worrying about this one. If this is a water alarm, then generally where would the actual alarm be located? Is this an enclosed float? How would you inspect this?
Cathay Hiatt
TasMar Inspections
(816) 260-1903
Adapt and Overcome
—Theodore Roosevelt
Old 10/21/10, 3:18 PM
Generally, this style of pump has a manual float and waterproof switch mounted on the side of the pump itself. When they break, sometimes the owner installs a simple mercury-style float switch.
Do you have a disclaimer of any type saying that you dont inspect pumps? If not, you should mention it. Sumps are funny, in that they work one day, and dont the next.
I'd ask you to examine where the two wires go to off this mystery rod. Give me some more photos and info. Is this thing mounted or just hanging? Also, look for what triggers and shuts off the pump.
Old 10/21/10, 3:23 PM
Okay...
I see the float switch. It is the black round thingy in the photo at around the 2-O'Clock position.
Upon closer examination of the mystery item... Is this thing metallic??!!
It almost looks like two strings with one of those tightener/adjuster slide devices... like a string handle to a pump pit cover.
See what it attaches to...
Old 10/22/10, 7:49 AM
The black item at the top right in photo is about a 3" pipe that appears to terminate outside above ground with a perforated cap over it. What I see at 2 o'clock is actually a wad of dirty spider web that looks different due to the camera flash.
THE MYSTERY ITEM is a metallic rod below that is dangling into the pit. The upper portion resembles elec. conductor in that it is rubber sheathed. I thought it was some type of sensor since there was not a float I could observe.
I would love to get more pictures. Do you think the homeowner will let me back in after I reported her main panel inaccessible due to the built in shelves in front of it????LOL
Cathay Hiatt
TasMar Inspections
(816) 260-1903
Adapt and Overcome
—Theodore Roosevelt
Hidden Sump Pump pabrioux Plumbing Inspections 6 4/7/10 12:04 PM
Sump pump requirements Matthew Klein Plumbing Inspections 0 12/30/09 3:53 PM
Sump pump question rnewman1 Plumbing Inspections 3 5/31/09 12:04 PM
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 4:38 PM
