Old 2/14/07, 6:43 PM
James H. Bushart's Avatar
Default Sump Pump Recall
Zoeller Pump Co. Recalls Septic Pumps Due to Shock Hazard
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in
cooperation with the firm named below, today announced a voluntary
recall of the following consumer product. Consumers should stop using
recalled products immediately unless otherwise instructed.
Name of product: Zoeller Brand Septic Pumps with a 20-foot black cord
with a plug.
Units: About 2,300
Manufacturer: Zoeller Pump Co., of Louisville, Ky.
Hazard: The plug on the pumps could have a grounding problem that could
pose an electrical shock hazard to consumers.
Incidents/Injuries: None reported.
Description: The recalled Zoeller brand septic pumps have a 20-foot
black cord with a plug. The pumps have date codes 0906 and 1006. On
models 53, 57, 151, 152 and 153 the date code is printed on the
nameplate on the top of the pump. On Model WM48 the date code is printed
on the tag near the plug. "Philippines" is stamped on the plug. A list
of specific part numbers, model numbers, date codes and UPC codes can be
found at www.zoeller.com. Pumps that have already been hard wired during
installation (where the plug has been removed) are not included in the
recall.
Sold by: Zoeller distributors nationwide from September 2006 through
December 2006 for between $125 and $375.
Manufactured in: Philippines (Cord with plug), United States (Septic
Pumps)
Remedy: Consumers should contact Zoeller to schedule an inspection,
replacement and return of affected pumps.
Consumer Contact: For additional information, contact Zoeller Pump Co.
at (800) 928-7867 between 8 a.m. and 4:30 p.m. ET Monday through Friday,
e-mail Zoeller at customercare@zoeller.com, or visit the firm's Web site
at www.zoeller.com
To see this recall on CPSC's web site, including pictures of the
recalled products, please go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07104.html
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 2/15/07, 9:50 AM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Sump Pump Recall
Thanks. I bought a Zoeller (53 or 57) recently but fortunately it does not have a 20 foot cable.
Metal case, no ground, water? What's the problem?!!!
Other than the recall, damn fine pumps. My old Zoeller pump was 15 years old (they are date stamped) and still working. Being rusty, I decided to replace it with the exact same model. It was such an easy fit.
After seeing this site I also replaced the receptacle feeding the pump with a GFCI.
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 4:38 PM
Sump pump I get all of the good ones cbottger Plumbing Inspections 5 5/29/07 2:48 AM
sump pump/ejector pump hziegenbein Plumbing Inspections 3 4/28/07 10:28 PM
Water powered sump pump rcooke Plumbing Inspections 7 1/6/07 8:32 PM
