Why would this surge suppressor be installed on sump pump or grinder pump? Thanks!
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
http://www.wagnermechanical.com/webapp/GetPage?pid=17
Safeguard your equipment With electrical power at a premium during the sticky summer months, utility companies often lower their output of power. This is normally called a brown out. A brown out or reduction in power can do irreparable damage to your appliances, especially your air conditioner. All appliances are designed to work with a certain amount of power. If that power level is dropped, your appliances will continue to function, but they will be forced to work under duress. A lightning strike to your home can damage or destroy all of your electrical appliances. With a lightning arrestor installed in your breaker box, you can protect all of your electrical appliances including your air conditioner, computer, refrigerator, microwave, dishwasher, stereo and televisions with a single dedicated lightning arrestor tied into your home’s electrical panel. This simple, inexpensive device can save you thousands of dollars in the event your home is ever struck by lightning. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks! Marcel. This was connected directly to the pump and sitting on the floor beside the sump pit
Buck,
Obviously, the pumps cord wasn’t quite long enough and he stole it…. I mean obtained the surge protector for free from work. |
| Surge Arrestor Installation | krichardson | Electrical Inspections | 3 | 9/27/09 4:20 PM |
| HELP - Surge protector/sub-panel set up | jfrederick | Electrical Inspections | 5 | 10/27/08 12:01 AM |
| Surge Suppressor Double Lugged | fpapp | Electrical Inspections | 3 | 6/1/07 9:41 AM |
| GFCI vs Surge protector | abishop | Electrical Inspections | 15 | 11/26/06 11:01 PM |
| Lighting surge | lagudo | Electrical Inspections | 5 | 8/30/06 11:49 PM |
