The discharge valve is plumbed up and 'T's into the primary condensate drain from the air handler which runs horizontally with an open hole (yes there's water flowing past it ...
How many call-outs are there here??? - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
all mentioned... plus PVC is not approved for TPRV drain line, but you knew that!
So BADAIR sez....3 ??
1) Not draining by gravity. 2) Joins primary condensate drain and 3) Uses improper material - PVC Are there anymore Barry? I'm genuinely wondering... I don't like the 'open hole bubble view' directly above the electrical connection for the water heater, but fail in the ability to convey that without calling people stupid... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Some other whiz-kid is going to come in and make the repairs you noted or not, you'll go back out and once again find fault with the craftsmanship or materials used. What's the big deal? Biz as usual! I'm done. Here's how we spell no fault divorce in Texas. maybe this is your case ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 4/28/08 at 8:01 AM.. |
Don't forget the draft hoods that are disconnected and placed next to the vent connectors....
