tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does the piping that extends to the floor need to be soldered? In the pic it shows the NEWLY installed T and P valve and piping...the coupler is NOT soldered....it is tight of course...but not soldered...shouldn't it be? Seems to me that it can come off and then it wouldn't be 6 inches from the floor anymore eh?
Should be Tony...
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
You could braze it.
In a year I could
How did you do today Tony....Good?....I'll bet so!.....
I wouldn't sweat it (no pun intended). The pipe should never be "pressurized" so no real issue as I see it.
Tony...did you get any of the code check books?
NO to the code checks.....but I am working on it.
AS for how I did...check my other posts Dale....and more to come I'm sure...I'm a bit worried......do you think I can talk the SE into letting me go with him as an interested 3rd party? (you will have to read my other posts to understand this) |
I don't see why not...why would he care.
You should find a retired or readily accessible engineer who you are able to call for things of this nature. If you ever start doing Technical Inspections they are handy to have come to the property for about $150.00 (here anyway). The engineer who works with me on Commercial Buildings is retired but still holds a current license and loves getting out to see things of this nature. An engineered guess is a third disinterested party....when he is just working for basically the client. His small report will keep you out of court...inexpensively. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
You could argue that point Jay, but you would be hard pressed to prove any requirement for securing the joint.
I would have checked it by hand to determine its integrity. If it came off easily, I would certainly note that it needed repair/correction. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
That is how I realized it wasn't soldered....I spun it in my hands
Why did this thread get moved? I specifically posted in members only area so that my clients wouldn't find my post and realize I was talking about their home.... sigh
Plumbing Contains discussions about plumbing.
Oopps....... Googles robots will not know what a T and P valve piping is...won't rank very high, page wise....... Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Bonding both hot and hold supply pipes | kshepard | Plumbing Inspections | 22 | 5/4/08 9:00 AM |
| NACHI releases a free, online Water Heater TPR Valve Discharge Piping mini course. | gromicko | Inspection Education & Training | 3 | 5/26/07 12:46 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 12:25 PM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 8:47 AM |
