on a tankless water heater how far away from the water outlet side can the Watts relief valve be?
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It doesn't matter how far as long as there is no valve/shutoff between the heater and the pressure relief valve.
There was a shutoff valve before the relief valve that I noted as wrong.
I was curious about the psi rating of cpvc over the psi rating of the relief valve. at higher temps the psi rating of cpvc decreases. What would be the probability that the line or a socket joint fails before the relief valve operates? Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Unlikely at best.
| Episode 49 - Tankless Water Heaters | inxil | NACHI.TV Inspection Videos | 0 | 9/10/08 1:59 PM |
| On Demand Water Heater | dgagneur | Plumbing Inspections | 10 | 3/30/08 10:57 PM |
| Home savvy magazine- tankless heaters | Brian A. MacNeish | Plumbing Inspections | 8 | 3/28/08 8:55 AM |
| Tankless Water Heater Recall | ldapkus | Plumbing Inspections | 1 | 2/22/07 8:34 PM |
