How should a Home Inspector inspect a tankless
waterheater ? New to the business David |
Most tankless water heaters are sealed units. If you remove the cover, you may void the warranty.
Do the inspection of the tankless as you would a standard water heater. Do check the exhaust flue and make sure that there is additional clearance around it. The required clearance information can be found in the manufacturer's installation guide. |
And for gas powered tankless water heaters, ensure that proper make-up air is present....these things can consume more air that some furnaces.
| Tankless Water Heater Recall | ldapkus | Plumbing Inspections | 1 | 2/22/07 8:34 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
