Old 6/24/08, 1:54 PM
Chris Tan Chris Tan is offline
Please Note: Chris Tan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Tankless water heater and pressure relief valve
The home I'm purchasing has a Takagi tankless water heater but does not have a temperature/pressure relief valve or a discharge line. We asked for this to be added and the sellers told us that per the codes for tank-less hot water heaters (California) a pressure relief valve nor a discharge line are needed. Is this true? If so, is it still a good idea to have one installed or does that fact that the heater is tankless make these items not necessary?
Thanks for everyone's input.
Chris
Old 6/24/08, 2:24 PM
Michael R. Boyett's Avatar
Default Re: Tankless water heater and pressure relief valve
Chris,
1. The tankless water heater should have been installed only by a qualified, Tagaki approved installer so it should be proper.
2. Tagaki and others, i.e. Bosch, Noritz, etc require a pressure only relief valve on the hot water output. Pressure only valves such as Cash Acme FWL-2, Zurn P3000BR, or Watts 174A would be required. Temperature sensing is done internally via an integral hi-limit switch.
3. Manufacturer's requirements supersede all others...it seems you do need a Pressure Relief Valve but it may depend upon your particular model. Contact your local Tagaki authorized installer for more information.
Here is an excerpt from a Tagaki installation manual:
Old 6/24/08, 3:34 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Interesting since the regular tank models have expansion tanks on the cold side.
Gotta think about that one.
Old 6/24/08, 3:36 PM
Michael Larson's Avatar
Expansion tanks and pressure relief valves serve two different purposes.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 6/24/08, 3:43 PM
relliott's Avatar
Yes and no
They both deal with the problem of water expansion.
Though I understand what you mean.(just had to get off post.)
Old 6/24/08, 3:46 PM
I meant to state TPR and expansion tank.
Michael Larson
Hudson, WI
InspectraPro
and
Old 6/24/08, 3:52 PM
relliott's Avatar
close enough
Old 6/24/08, 5:59 PM
Jeffrey R. Pope's Avatar
Chris
A relief valve is absolutely necessary with any type of water heating device. A combination temperature/pressure relief valve is only required with storage-tank type heaters.
The relief valve doesn't necessarily need to be near the heater, although most competent installers will generally place it relatively close to the heater.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/24/08, 7:38 PM
relliott's Avatar
Makes sense
Old 6/25/08, 4:03 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Good post Jeff. Tankless water heaters are subject to the same type of failures that tank type water heaters occasionally suffer from.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 6/25/08, 7:19 PM
Chris
I'm starting to see these more frequently, usually coupled up with a holding tank and a high velocity heating system. They always have relief valves.
Old 6/26/08, 1:11 AM
John, What is a High Velocity Heating System?
Is that another name for Instant Heater.
Thanks.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 6/26/08, 1:18 AM
relliott's Avatar
Jack did you make that diagram.?
Old 6/27/08, 2:13 AM
No it came from one of takagi installation manuals.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
TPR valve acox Plumbing Inspections 19 5/27/07 1:36 PM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
Water Heater Pressure Valve wrosario Plumbing Inspections 3 7/7/06 8:27 PM
