Would you comment on this & if so, why? House is 14 years old and furnace & water heater operated/vented properly. I understand with natural draft that a wye would be better here, but does anyone have any documentation supporting this install and what affects it can have with venting? BTW, the water heater vent is properly pitched up to the tee fitting.
Thanks in advance. |
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
I don't have a problem with it. The pitch looks OK.
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a problem. The water heater appears to be the lower vent. It's hard to tell from the picture. If it is.... then
EDIT: On a second look, it looks like the furnace is the lower appliance in the picture. Ignore below Is the lower BTU appliance connected above the higher BTU appliance? The water heater should be connected above the furnace. |
I'm thinking the water heater is the upper vent.
If I were to call out every Tee connection at the exhaust area, it would be in 1/3 of the homes I inspect.
I simply note the connection. As for the sizes of the vents and their placement...the smaller vent connector should vent into the chimney above the larger vent connector...
Correct.
Thanks for the replies, fellas. |
It should be okay as long as there is not a draft motor on one of the appliances.
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
