Has anyone ever seen a temperature pressure relief like this one? The electric water heater is 50 years old and 52 gallon. The brand name is PRESTO.
The discharge is undersize to what is required now Most new ones require 3/4 discharge to with in 8 inches of the floor. This tank sure is close to the end of its life remind the purchaser to budget for replacement. Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Thanks, Roy
Harry are you sure that was not POS?
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I think I would recommend that unit be replaced before it leaks and causes a mess.
No, Bruce, that is the hot water suppy pipe coming out of the water heater under the temperature relief valve. Thanks!
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
T.Neyedli www.alphahomeinspections.ca |
| Hydrostatic Pressure Test | Edward D. Wend | Plumbing Inspections | 9 | 6/5/07 4:58 PM |
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 1:36 PM |
| Think we should open this up to all inspectors & public, possibly saving lives? | gromicko | Miscellaneous Discussion for Inspectors | 34 | 5/27/07 12:12 AM |
| Hot Water Tank - missing Pressure relief valve? | Jan Lombard | Plumbing Inspections | 31 | 4/12/07 4:32 PM |
| Water Heater Pressure Valve | wrosario | Plumbing Inspections | 3 | 7/7/06 8:27 PM |
