Old 6/14/08, 1:17 AM
Gregory C. Scheer, Jr. Gregory C. Scheer, Jr. is offline
Default Tprv
Am I missing something with the TPRV venting? Isn't it supposed to to visible to the end, terminating within 6 inches from the floor/drain pan? I've seen in my area the pipe sent through the wall to outside. Maybe I'm missing something--please advise.
Greg
Old 6/14/08, 1:28 AM
Christopher Currins's Avatar
Default Re: Tprv
  1. Be first piped to an indirect waste receptor through an air gap located in a heated area when discharging to the outdoors in areas subject to freezing, since freezing water could block the pipe.
Water Heater Discharge Piping mini-course for inspectors.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 6/14/08, 1:38 AM
Default Re: Tprv
Exactly, but what I've seen goes against the courses. Hmmmm... New construction too! Crazy!
Old 6/14/08, 1:43 AM
Default Re: Tprv
How high are they set off of the ground? Inside are out, they still fall under the same requirements.
Christopher Currins
Certified, Licensed
Old 6/14/08, 1:55 AM
Default Re: Tprv
Thanks. As suspected; I just don't understand how they're passing code inspections.
Old 6/14/08, 2:06 AM
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Tprv
I see the same thing here in Georgia. Piped right through the wall at a straight angle. Most always in the basement. I call it and take the flack. I also don't know how it passes inspection.
Had one this week but it was also reduced to 1/2 inch and no expansion tank installed.
The expansion tank was still in the box in the corner.
Old 6/14/08, 5:29 PM
jkogel jkogel is offline
Default Re: Tprv
Christopher, is that a Chicago area rule?
I don't see freezing as even a remote possibility in California, even in the Sierras (or in Chicago, either for that matter) as the only water coming down the pipe is a boiling hot splatter, once in a blue moon.
If it's new construction, I would make inquiries about locally accepted practice. Should be recycling that heat.
John Kogel
www.allsafehome.ca
Old 6/14/08, 6:18 PM
Jeffrey R. Pope's Avatar
Default Re: Tprv
Based on your very vague description, it doesn't sound improper to me.
First of all, you're in CA. IRC rules don't apply. The termination is required to be between 6" and 24" off the floor - not "within 6".
Secondly, unless your in an are that is subject to freezing temperatures, a "through-wall" termination is perfectly acceptable, so long as the termination (not the entire pipe) is visible.
Rarely will you see a discharge in CA that includes an air-gap or indirect waste connection/receptor.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/14/08, 10:36 PM
Default Re: Tprv
John Kogel
www.allsafehome.ca
The "rule" came from...Water Heater Discharge Piping mini-course for inspectors. There are other parts of Illinois besides Chicago.
Christopher Currins
Certified, Licensed
Old 6/15/08, 12:20 AM
Default Re: Tprv
Sorry CC, I see you are closer to St. Louis Mo than Chicago.
Old 6/15/08, 2:47 PM
Default Re: Tprv
Here's what the hot water heater looks like. Where do I look to see if this is acceptable? I've already performed a search for CA plumbing code and I don't find it. Thanks for the help.
Greg
Old 6/15/08, 4:11 PM
Tab M. Wilcox Tab M. Wilcox is offline
Please Note: Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Tprv
It is very common here for the pipe to be routed through the wall. The pipe is usually ~ 8"-10" above grade and has a 90 degree fitting to direct the discharge towards the ground. I have seen plenty without the 90 degree fitting, which I would report on.
Old 6/15/08, 4:36 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Default Re: Tprv
Here's mine from yesterday. Not a good picture but the copper line went up and ended about 6-8 inches from the bottom side of the subfloor. Around here about 75% discharge to an exterior point, and almost always uphill.
Old 6/17/08, 9:59 AM
Default Re: Tprv
Around here there are a lot of heaters installed in interior closets, under stairs, etc. that discharge into the crawl space below. In some cases the space is so tight that the pipe cannot even be seen.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 6/18/08, 2:46 AM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Re: Tprv
check out http://www.nachi.tv/ppv/8
Plastic TPRV line? rmaday Plumbing Inspections 14 6/5/08 7:50 AM
TPRV questions Rick Maday Plumbing Inspections 1 8/23/07 1:51 AM
TPRV drain piping tsmith5 Plumbing Inspections 4 1/11/07 11:25 PM
TPRV drain cbuell Plumbing Inspections 1 1/5/07 9:22 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 8:59 AM
