I know this has been discussed before, however, I'm being challenged by the plumber (via the seller). The question: Is there pvc rated for tpr drain lines? The plumber says its fine. It was my contention that it was not, and had to be hard pipe. I told the seller that if the plumber says otherwise to please provide me with some documentation to update my records....Thanks for your help!
Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
CPVC is approved but not regular pvc.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
The tprv drain pipe can be made of plastic but it must be rated for the water pressure and temperature.This is stamped along the length of the pipe.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Make sure the 90's are also CPVC
James,
CPVC is all good here in Quebec-Canada |
While I don't like to see it... it is approved in many jurisdictions. Know your area...
That being said, there is a CPVC line specifically designed for TPR drains which is blue-green in color; however, standard CPVC is typically allowed again depending on the codes in your area(s) Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
| CSST Pipe question | sjohns | Inspecting HVAC Systems | 4 | 8/1/09 5:43 PM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| TPR Drain pipe | mwood1 | General Inspection Discussion | 18 | 3/10/08 6:05 PM |
| Question about mold on the inside of a drain pipe | abishop | Plumbing Inspections | 3 | 4/11/07 9:35 PM |
| drain pipe | nbhi | Plumbing Inspections | 6 | 4/5/06 10:51 PM |
