Old 8/26/08, 3:00 PM
jachin jachin is offline
Default TPRV extention materials
Will someone please list all the acceptable materials for use for TPRV
extentions.
thankyou.
Old 8/26/08, 3:58 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: TPRV extention materials
Galvanized steel, hard-drawn copper, CPVC
Stephen Stanczyk
Old 8/26/08, 5:05 PM
Thanks Stephen,
My code check book says that you can use the same materials allowed for water distribution, but it doesn't list pex (it lists the same materials that you listed). I have seen pex used frequently and write it up as wrong, but it is accepted for water supply. Do you write up pex when used for TPRV extension?
Old 8/26/08, 5:21 PM
Michael Larson's Avatar
Pex is fine for the TPR discharge.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/26/08, 5:46 PM
Jeffrey R. Pope's Avatar
It depends on your AHJ, but Mr. Larson is correct - PEX is generally accepted for this use. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/26/08, 6:04 PM
thanks guys
Old 8/26/08, 9:35 PM
The problems with PEX are minor.
It needs to be secured more than the other materials since it is more flexible.
It is also affected by sunlight so if the water heater is in say a utility room with a window, the PEX should be covered. If the TPRV is routed to the exterior as it should, the termination point in sunlight should be protected or a different material.
For the supply lines, there must be 18" of metallic or approved piping between the water heater and any PEX. It makes sense that it would be for the TPRV also. Just a thought.
Stephen Stanczyk
Old 8/26/08, 10:56 PM
Hi Stephen,
Could you provide the source for this requirement, please?
Larry Kage, CMI
231 929 3525
Old 8/26/08, 11:45 PM
Uniform Plumbing Code (2003). I know some don't go by the UPC but some of the manufacturers quote this in their installation guidelines. There are parts made specifically for water heater and PEX connections..
Stephen Stanczyk
Old 8/27/08, 12:19 AM
Stephen is correct. . .
604.11.2 Water Heater Connections.
PEX tubing shall not be installed within the first eighteen (18 inches (457mm) of piping connected to a water heater.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/27/08, 1:36 PM
The TPRV extension should terminate 2 -6 inches from the ground. It must be visible and not be routed to a crawlspace or exterior.
Old 8/27/08, 1:53 PM
Sorry to disagree, you are only partially correct. It should not terminate in the crawl space. But the best application is to route to the exterior, to within 6" of the ground.
Stephen Stanczyk
Old 8/27/08, 3:45 PM
Actually you are both correct, depending on which code your area follows. The Uniform Code says the termination should be between 6" and 24" from grade or finished floor, and the International Code says not more than 6" from grade or ff.
Also, with manufactured homes, Federal guidelines allow a termination into the crawl space.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/27/08, 4:59 PM
"2. Discharge through an air gap located in the same
room as the water heater.
7. Discharge to a termination point that is readily
observable by the building occupants."
Old 8/28/08, 9:06 AM
Ahh, the UPC...thanks, gentlemen.
Larry Kage, CMI
231 929 3525
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 2:30 PM
IAQ: moderating humidity in homes using absorbent wall materials kshepard Green Building Inspections 0 1/17/08 1:27 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 8:59 AM
