Thermal blanket on water heater. Do they really serve a purpose anymore? What do you say about them?
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
The new water heaters are very well insulated. I had a code official red tag the installation of my new water heater in the garage for not having a blanket........ until I showed him the Manufacturers installation instructions that said none was needed. In fact it recommended that one not be installed.
When he left with a harrumph..... I smiled...... and kept smiling for hours. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Good for you !
Water heaters do not need insulation blankets as they are factory insulated already.
When I do find them, its wrapped around an electric water heater. I don't even call them out anymore. I simply tell my clients that they are not needed. |
In fact, some manufacturers will void their warranties if a blanket is installed.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
True: A thermal image before/after a thermal blanket install would reveal it does help. Im planning to install one on mine, my warranty is gone anyway. |
I write a limitation comment in the inspection. That it limits inspection of the unit. Unless you can remove it you can not see the whole tank. And it may hide issues.
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
rdawes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Getting a good image with one installed will be very difficult if it has a reflective outer coating as many of them do.
Proper emissivity settings will help.
| flammable vapor ignition resistant | dbaucum | General Inspection Discussion | 35 | 2/19/08 2:42 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/25/07 12:28 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 10:18 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 10 | 1/11/06 10:53 PM |
