I got one that stumped me today.
Replaced electrical water heaters in 2003 on a 1950's home. Plumber stated that expansion tanks were not needed because of the type of meter valve at the street? It was a opened end system and not a closed system like newer homes, therefore did not need a thermal expansion tank? Wow never heard of this. I hope I stated this well enough where it makes some sense to a plumbing guru.... |
Here's what the UPC says. . .
608.3 In addition to the required pressure or combination pressure and temperature relief valve, an approved, listed expansion tank or other device designed for intermittent operation for thermal expansion control shall be installed whenever the building supply pressure is greater than the required relief valve pressure setting or when any device is installed that prevents pressure relief through the building supply. The tank or device shall be sized in accordance with the manufacturer’s recommendation. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks for the reply Jeff. But I am not sure if this answers my question? Or does it?
Primarly with the type of water meter he stated that was installed at the street being a ''open pressure system'' versus a ''closed pressure system'' ? This I never heard of. Is there in fact several or 2 different types of water meters/valves? Or does a thermal expansion tank or device similar need to be installed regardless? |
| Expansion tank immediately downstream of main shut-off? | pcoulter | Plumbing Inspections | 11 | 1/30/08 12:00 PM |
| Thermal Expansion Tank--Required? | gsloan | Plumbing Inspections | 8 | 10/14/07 12:16 PM |
| Septic System Care | mlarson | Ancillary Inspection Services & Additional Topics | 52 | 8/31/07 10:26 PM |
| Expansion Tank Question | cpetty | Plumbing Inspections | 9 | 9/25/06 7:13 PM |
