Old 3/13/08, 10:30 PM
Default What are these things?
White 4" pipes sticking up about a foot above the basement slab. They could be rough-ins for future plumbing waste but they're the wrong kind of pipe and why would they be out in the middle of the floor like this?
They look like risers for venting something but what? Are they connected to the line from the perimeter drain to the sump pit? Why?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 3/13/08, 10:32 PM
Jeffrey R. Jonas's Avatar
Default Re: What are these things?
Radon Mitigation???
Old 3/13/08, 11:09 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Rough in for possible bath room fixture or sink.
Old 3/14/08, 12:08 AM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
agreed
Old 3/14/08, 6:41 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Unless they were planning on using the sump pit as a mini septic tank, I doubt that was the intention.
More than likely it is some sort of sub-slab ventilation to prevent water pressure from building up under the slab and creating hydrolic pressure. Is there low permiable soil or a high water table in the area where the house was built?
Old 3/14/08, 9:46 AM
Edward Bibb Edward Bibb is offline
Please Note: Edward Bibb is a non-member guest and is in no way affiliated with InterNACHI or its members.
seems if it was a vent, then vent to the exterior. Are they connected to each other? They are oddly placed in the corner of the rooms... as if under a planned piece of furniture... perhaps a cat5/coax conduit.. (overkill)
Old 3/14/08, 10:33 AM
I'd expect to see a waste line for a toilet up against the exterior wall with rough-ins for water supply. These things were out in the middle of the floor. Wierd places to think someone might decide to put a camode.
No one in their right mind would vent a passive radon mitigation system to the living space.
Sump pits make the tiniest septic tanks... got to have them pumped four times a day!
There was 14 inches of water in the sump pit. I think you've got it Scott, thanks.
(303) 717-8940
Old 3/14/08, 10:37 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree w/ Erol + Chris. The "sump-pit" looks to be sealed and is most likely a pit for an ejector pump. Seems they could have plumbed in the ejector pump, though.
Old 3/14/08, 11:48 AM
tdietrich1's Avatar
Doesn't look like a 'gas-tight' sewage pit, especially right next to the egress window?
Have to have peaked in the pit, was the lining perforated?
tom
Old 3/14/08, 12:57 PM
rmaday's Avatar
tom
I was looking at pic #1. Looks like a different location from the lack of "astroturf".
Old 3/14/08, 1:47 PM
tdietrich1's Avatar
It is, from what I see, so we agree. What I was pointing out, was if it is the only egress window in the basement, if you frame in the bathroom, you now have removed it from the basement. See?
tom
Old 3/14/08, 7:14 PM
Originally Posted by jjonas
Radon Mitigation???
What are these things?3/14/08 4:59 PMfor real?
Yes...for real...I never said the system was completed...could be for future installation if in a high Radon Risk area... Think what you will, I see all kinds of systems and designs in Minnesota... nothing surprises me anymore!!!
http://www.epa.gov/radon/pubs/hmbyguid.html
Old 3/14/08, 7:21 PM
rmaday's Avatar
Interesting!
Whatever it is for it is certainly not completed.
Nice pic
Old 3/14/08, 8:39 PM
jkogel jkogel is offline
Radon Mitigation???
That was my first thought. Dumb locations, too.
Old 3/14/08, 11:52 PM
They were capped. The pit was not sealed and had an incoming line consistent with a perimeter drain. That EPA image looks very similar to the condition I found.
(303) 717-8940
Fun things you find hvalenzano Miscellaneous Discussion for Inspectors 2 6/10/07 4:33 PM
Inspector Wendy's Home Inspections-Service Areas wforsyth Miscellaneous Discussion for Inspectors 57 9/5/06 11:10 PM
