I've not seen a trap set up quite like this....any thoughts?
Thanks in Advance! George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Not allowed by the Uniform Code.
Because of three traps to one drain?
Multiple traps on one trap-arm (the horizontal portion connected to the vertical drain line) is specifically prohibited by the UPC.
Three drains served by a single trap and trap-arm is what the UPC requires. The IRC, however, allows multiple traps on one trap-arm. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thank you sir!
I only see a 45 degree elbow going uphill on the disposal.
More pics on other computer will try to post pics of the other side later. 3 p-traps.
I would like to see more also.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
I only had the one more and it wasn't as good of a pic as I remember but here's both side by side.
| T200/T250 Thoughts? | rking6 | Thermal Imaging, Infrared Cameras & Energy Audits | 3 | 6/25/10 7:48 PM |
| Need thoughts, low water pressure issue. | mroberson | Plumbing Inspections | 4 | 8/1/09 1:26 PM |
| Thoughts: Combustion Air Vent | pdoane | Inspecting HVAC Systems | 1 | 9/26/08 1:41 PM |
