Anybody know what type of set up this is?
| Find an InterNACHI certified New York Home Inspector (and anywhere else in North America) |
Circulating pump.
W/H supply piping will be at the top of the tank.
This appears to be a supply to something behind the wall. Where does this supply piping go? |
I agree with Brian...it's likely a whole house hot water recirculating pump but I don't know why there are two timer mechanisms...one feeding the other. Perhaps the one on the pump itself is defective and the homeowner simply 'replaced' it with the outlet mounted appliance timer. Usually no need to circulate hot water to the fixtures at 3:00 am you know.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
If the original timer is still functioning it cannot be at the right time very often. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Probably stuck on as there are no pins.
Is this a system for instant hot water ?
The pump keeps the hot water moving through the system so you do not have to wait for it to travel from the Hot Water Tank.
So Yes. Hmmm No drip leg visible |
For those of you who have not seen a passive re-circulator, here is one from yesterday.
David...here's a diagram of a simple system. Google "hot water recirculation system" and you will get plenty of information.
The thing I have always had a hard time with is..
Why does the recirculation pump not push hot water back into the cold supply and only push it around the hot water supply pipes if there is no check valve on the cold water side.? . |
Bob the loop is formed from the hot side of the far fixture back to the cold inlet of the water heater.
Ok
But since it adds ore pressure to the tank you would think that it would add that pressure equally to the cold water inlet and the hot water outlet . That is the concept that I have a hard time grasping. If the cold water side had a check valve I could see the pump circulating the hot water supply only. (But it has 2 paths it could potentially follow as the tank has 2 openings). (Ok 3 counting the pump at the bottom drain). |
Follow the yellow line. There is no open loop on the cold side.
tom |
| Client wants a new water heater | adirienzo | General Inspection Discussion | 47 | 7/14/10 3:03 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/25/07 12:28 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 10 | 1/11/06 10:53 PM |
