Toilet valves that spray out the top. See the picture is it normal, I see it a lot. Also is it a big deal when the overflow tube does not have that small water line going to it from the fill valve.
I would suggest fixing it.
The little fill hose is how the bowl water refills so yes ,just clip it back in. |
No and Yes, it probably needs replaced. It will sure cut down on the water bill.
Its a defect. Write it up and let them fix it how they see fit. some will replace it. others will leave it.
So I am right the valve should definitely not spray out the top?
correct
Water shouldn't be spewing out at that fill valve tube. It should have a hose attached to it and conveying the water into the overflow pipe
See the small black tube at the top center of this image...
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
