Old 11/1/07, 7:47 PM
thirst's Avatar
thirst thirst is offline
Default Toilet caulking
Is a toilet supposed to be caulked at and around the bottom at the floor. Seems like I have heard both ways but am not sure how to call this? It makes sense to me that it should but I need to be able to back it up with fact not just making senses. Any help would be great. Thanks guys!!!!!
Travis Hirst
Hirst Home Inspection and Inventory Services, LLC
www.HirstHome.com
Travis@HirstHome.com
Old 11/1/07, 7:58 PM
ldapkus ldapkus is offline
Default Re: Toilet caulking
If the wax seal springs a leak how will you know?? When you end up in the basement???
Old 11/1/07, 8:00 PM
tdietrich1's Avatar
Caulking helps keep it clean. I've learned this with potty training a little boy. You caulk like 90%, leaving the back open, so if someone misses the potty, you don't have stuff growing in the groove.
Tom
Old 11/1/07, 8:01 PM
phinsperger's Avatar
It doesn't "need" to be caulked at all but it sure looks better. Some people only caulk the front and sides and leave the back open so that it it leaks you are supposed to know sooner. If its not caulked, an over flow from any the fixtures could get under and around the drain.
So you see, there is + and -
Old 11/1/07, 8:03 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
I caulk the whole thing but only because my wife cleans the floor like a sailor swabbing the deck of an aircraft carrier!!
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 11/1/07, 8:08 PM
thirst's Avatar
So if you do an inspection and it's not caulked do you call it out or just let it go? How do you write it up?
Travis Hirst
www.HirstHome.com
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
My tile setter used grout around the toilet. Looks pretty good....if you like looking at that sort of thing.
As far as reporting...to me it is an item not worth mentioning either way.
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 11/1/07, 8:17 PM
tdietrich1's Avatar
Push brooms and fire hoses?
tom
Old 11/1/07, 8:21 PM
Christopher Currins's Avatar
It's a cosmetic issue.
Christopher Currins
Certified, Licensed
Old 11/1/07, 8:29 PM
tom
With as much water, and chemicals, that go on the floor you would think it was push brooms and fire hoses. Our house is custom built and during building I had the entire bathroom floor, both bathrooms, equipped with the equivalent of hot mopped shower pans and drains!!
TREC License# 7593
Old 11/1/07, 8:33 PM
Bob Elliott's Avatar
I agree that leaving an opening at the back is the best option.
I feel having a good portion caulked with a silicon sealant is not only a good way to keep it clean around the perimeter but also helps in keeping the ring seated by eliminating more movement than a tightened bolt.
Think about it and you realize they will only tighten it so much to avoid cracking the porcelin.The caulk will help eliminate any small movement that contributes to a loose wax ring.
Old 11/1/07, 9:23 PM
mthomas2 mthomas2 is offline
EVERY wax ring is going to leak, most within a decade or two. I've seen water wicked through OSB subflooring down a hall and into a bedroom 20' away. IMO a pretty high price to pay for avoiding a bit of cleaning.
Old 11/2/07, 1:08 AM
I agree with Robert. The life of a wax ring will be extended because the caulk at the floor eliminates any small movement. It really holds the toilet in place well. Better than a couple of cheesy bolts into OSB.
But to answer the original question, I don't write it up. A toilet install does not need caulk at the base of the toilet.
Old 11/2/07, 12:45 PM
thirst's Avatar
Thanks for the answers guy's. I do agree that it will eliminate most unwanted movement at the base which may help lessen the chance of a leak. I did not write it up as I knew it was not a must have situation. I did however give some recommendation to the buyer just for his information. Thanks again for all the info and quick response to the question.
Travis Hirst
www.HirstHome.com
Old 11/2/07, 2:17 PM
Barry Adair's Avatar
You'd be surprised what will grow around this environment
Anyone for shrooms?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
My toilet won't flush Matt Piercy Plumbing Inspections 22 9/28/07 2:27 PM
Hot water toilet hmcbride Plumbing Inspections 16 4/26/07 8:25 PM
Toilet Does Not Always Flush...Why? Homey Plumbing Inspections 20 10/16/06 1:13 AM
Toilet in bedroom!? ngifford Plumbing Inspections 14 2/18/06 11:43 PM
