Old 10/9/07, 12:55 PM
kmcmahon kmcmahon is offline
Please Note: kmcmahon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Toilet guru's
Thought I'd ask you toilet guru's about this.
Toilet fill valve comes on every so often...maybe once an hour for about a second and shuts off.
What is happening to cause this?
Old 10/9/07, 12:57 PM
Michael Larson's Avatar
Default Re: Toilet guru's
Not a GURU says:Slow leak in the flapper valve. Monitor the water level in the tank to verify.
Old 10/9/07, 2:11 PM
I just had this happening after R & R of toilet when installing hardwood in our master bathroom...I removed the rubber flapper and cleaned the bottom of it and re-installed it...problem solved.
Larry Kage, CMI
231 929 3525
Old 10/9/07, 8:15 PM
Charley L. Bottger's Avatar
Not a GURU
Mike there is a name for people who play in commodes and no its not Guru.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/9/07, 8:18 PM
Bob Elliott's Avatar
Also check that if it is a chain type it's not catching on something.
Old 10/12/07, 12:52 AM
dbronsted's Avatar
dbronsted dbronsted is offline
Yes you have a slow leak...somewhere...if there is sediment or rust laying in the bottom of the tank it will cause the flapper to leak..im sure you have looked for leaks in other places..the valve is just replacing lost water..important these days ..Atlanta is fixin to have to go to rationing soon if we they dont get a lot of rain
My toilet won't flush Matt Piercy Plumbing Inspections 22 9/28/07 2:27 PM
Hot water toilet hmcbride Plumbing Inspections 16 4/26/07 8:25 PM
Toilet Does Not Always Flush...Why? Homey Plumbing Inspections 20 10/16/06 1:13 AM
Toilet in bedroom!? ngifford Plumbing Inspections 14 2/18/06 11:43 PM
