I sat back and relaxed then flushed
Tank was not bolted properly on all toilets in this three bath condo, they all gushed when flushed, but only when you sat back Unfortunately homeowner used them this way and floors/base/walls were damaged badly...watch how you inspect ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 1:56 AM.. |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just mark it down as a bidet.
Barry, If you are going to use one of those things to relax and relieve, it is not designed to be a lounge chair, you probably over exercised the tension of the bolt connection between the tank and the flush. ha. ha. You should differ from using the sellers property to relieve yourself on paid time. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
It was a "stress" test.
Who here has used the facilities before making sure the water is on??????
| My toilet won't flush | Matt Piercy | Plumbing Inspections | 22 | 9/28/07 3:27 PM |
| Sweating Slab or Plumbing Leaks | Skip Erwin | Plumbing Inspections | 1 | 5/2/07 3:21 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
