Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
LinkBack Thread Tools Display Modes
Old 10/17/08, 9:14 PM
Mark Nicholet's Avatar
Mark Nicholet Mark Nicholet is offline
Mark Nicholet is well trusted Mark Nicholet is well trusted Mark Nicholet is well trusted
Default TPR against drywall
Is there potential for the TPR valve to not operate correctly with the stem being tight against the drywall like this? Or will the spring mechanism still function correctly? Thanks
Mark Nicholet
Apple Home Inspections
Old 10/17/08, 9:37 PM
Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute
Default Re: TPR against drywall
I guess testing it to see if it works or will work on its on is out of the question Mark.
Nice pick up.
Marcel
Cyr Home Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards/inachiawards551.html
Commercial Builder
Ouellet Associaties Inc.
Old 10/17/08, 11:51 PM
jkogel jkogel is offline
jkogel is well trusted jkogel is well trusted jkogel is well trusted
That's the before picture, this one is after they call the plumber back in.
John Kogel
www.allsafehome.ca
Old 10/23/08, 11:04 AM
John Allingham is generally well trusted John Allingham is generally well trusted
It won't work. The TPR valve stem has to be able to move outwards.
Old 10/23/08, 5:07 PM
Ian A. Niquette's Avatar
Ian A. Niquette Ian A. Niquette is offline
Ian A. Niquette is well trusted Ian A. Niquette is well trusted Ian A. Niquette is well trusted Ian A. Niquette is well trusted
That would be correct. It will not work.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Old 10/23/08, 7:31 PM
Ronald G. Chorey II's Avatar
Ronald G. Chorey II Ronald G. Chorey II is offline
Ronald G. Chorey II is generally well trusted
Send a message via MSN to rchorey
Is it in a garage? Because the plumber just broke the firewall if it is by putting a hole in the drywall. He must be from here!!!
Old 10/23/08, 11:03 PM
Nah, the tank with the hole was inside. Better a 2" hole in wall in any case.
John Kogel
www.allsafehome.ca
Display Modes
Any requirement for drywall around a furnace? Nathan W. Swilling HVAC 1 8/20/08 4:00 PM
Popcorn Ceiling prubenstein General Inspection Discussion 10 2/7/08 11:12 PM
Drywall finishing dmacy Misc. Discussion 17 1/25/07 2:29 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
