Old 12/30/08, 4:24 PM
Bob Elliott's Avatar
Default TPR and flush valve on T
Is it ok to have the tpr valve joined with the flush valve into the floor drain?
Will provide .a picture later after I down load.
Just do not recall seeing it before.
On a hot water tank of course
Old 12/30/08, 4:26 PM
Michael Larson's Avatar
Default Re: TPR and flush valve on T
Waiting for pic Bob but it doesn't sound right.
Michael Larson
Hudson, WI
Old 12/30/08, 5:18 PM
Michael R. Boyett's Avatar
No, a TPRV discharge "shall be piped full size separately to the floor, to the outside of the building or to an indirect waste receptor located inside the building". But, then again you are in Chicago so who knows?
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 12/30/08, 6:26 PM
klott's Avatar
klott klott is offline
No it is not O.K.
"It's not what you believe that matters...it matters what you believe!"
Old 12/30/08, 6:42 PM
Ok ,sorry but I took a nap.
Here is a picture and please explain the reasoning if you know it.
Old 12/30/08, 7:10 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Attachment 25875
Yeah i'd say that is obviously F 'ED up.
There needs to be an air gap, something to do with anti blockage. What if the drain clogs????
It looks like only efficiency was observed but with disregard for safety.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Old 12/30/08, 7:14 PM
Yeah that was my first thought.
Lake point tower and they use FPE stab loc,plus lint buckets for dryers there.
Second time inspecting there and both had that.
Got any lingo to back me up?
Old 12/30/08, 7:19 PM
Jeffrey R. Pope's Avatar
The "reasoning" would be that the installer just didn't know any better.
I won't speculate as to "why" people do what they do, but I'm happy to point it out when they don't have a clue. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/30/08, 7:26 PM
Thanks Jeff but that is not straight enough.
I just found out I have part of IPC here on file from a Frank Carrio submission.
504.6 Requirements for discharge piping.
The discharge piping serving a pressure relief valve, temperature relief valve or combination thereof shall:
1. Not be directly connected to the drainage system.
2. Discharge through an air gap located in the same room as the water heater.
3. Not be smaller than the diameter of the outlet of the valve served and shall discharge full size to the air gap.
4. Serve a single relief device and shall not connect to piping serving any other relief device or equipment.
5. Discharge to the floor, to an indirect waste receptor or to the outdoors. Where discharging to the outdoors in areas subject to freezing, discharge piping shall be first piped to an indirect waste receptor through an air gap located in a conditioned area.
6. Discharge in a manner that does not cause personal injury or structural damage.
7. Discharge to a termination point that is readily observable by the building occupants.
8. Not be trapped.
9. Be installed so as to flow by gravity.
10. Not terminate more than 6 inches (152 mm) above the floor or waste receptor.
11. Not have a threaded connection at the end of such piping.
12. Not have valves or tee fittings.
13. Be constructed of those materials listed in Section 605.4 or materials tested, rated and approved for such use in accordance with ASME A112.4.1.
Looks like #4 covers it and I wonder about #2 as it leaves me confused.
I would also note lack of a drain pan.
They have 2 heaters with one in the kitchen and one for the bathroom .
Both are electric with no gas in this 68 story building.
hmmmmmmm. here is some thing but still looking.
.....c) With the exception of special water heaters used for space heating in addition to hot water supply, as provided in subsection (a)(9) of this Section, water that leaves the potable water system for heating, cooling, use in equipment or other similar uses shall not be returned to the potable water distribution system. When such water is discharged to the building drainage system it shall be discharged through a fixed air gap.
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 12/30/08, 7:29 PM
hmmmmmmm.
Yeah
I was suprised to and since the bottom 2 screws were missing on a loose cover I opened the FPE.
Old 12/30/08, 7:34 PM
Section 890.APPENDIX H Indirect Waste Piping #1
Section 890.ILLUSTRATION E Indirect Waste Connection
(Referenced in Section 890.1010(b))
"TPR discharge pipe should have an air gap at the terminating end that is within 6 inches of floor. " hows that sound
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 12/30/08, 7:39 PM
Mike covered that in post #3. . .
An air-gap is used when the extension is routed to a point where it would be subject to freezing. Unfortunately, air-gaps are not very effective for the pressure and volume produced by a relief valve.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/30/08, 7:41 PM
Barry Adair's Avatar
that galv. ell sure looks threaded from texas, but who's writing this report
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/30/08, 7:47 PM
Good catch,almost missed that (ha)
I had to move a little faster than normal and am looking at pics to make up for it.
