Old 12/30/11, 12:44 PM
Jeffrey M. Cohen Jeffrey M. Cohen is offline
Default TPR connected to hose
Found this in yesterdays inspection. A hose was connected to TPR which lead to sump pit. Haven't seen this before and I don't think its a good idea. If tpr is leaking how will you know, so I called it out. Who else has a problem with this.
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/30/11, 1:14 PM
Jeffrey R. Jonas's Avatar
Default Re: TPR connected to hose
I would hope that everyone here has a problem with it. I know I do.
Btw... I would take that as a clue that the TPRV is actually leaking.
Old 12/30/11, 2:46 PM
The word Whip comes to mind
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/30/11, 2:48 PM
Michael Larson's Avatar
Maybe KEVIN will chime in.
Michael Larson
Hudson, WI
Old 12/30/11, 2:49 PM
Joe Funderburk, CMI's Avatar
Piping has to be approved for distribution piping. "Hose" is not.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/30/11, 4:07 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Sorry I only follow the InterNachi plumbing inspection guidlines and am not a Code Inspector but right it up anyways and back it up by the 2006 RBC.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/30/11, 4:10 PM
So, since you are not a code inspector, you are saying this is okay???
Kevin, meet "The Meeker". "The Meeker", meet Kevin.
I don't know what else to say!!!
Old 12/30/11, 4:11 PM
Funny, I don't care who you are!
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/30/11, 4:16 PM
I suspect "The Meeker" may take issue with it!
Old 12/30/11, 4:36 PM
KEVIN WOOD's Avatar
Does InterNachi say it is OK! I think not.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/30/11, 4:43 PM
And the back-peddaling begins...!
Old 12/30/11, 6:44 PM
Bob Elliott's Avatar
End of hose is not visible to view leaking ,pipe should be the same as that approved for water supply pipe,see no required 1/4" per foot slope.(no threaded pipe allowed to prevent additions is allowed)(Nice workaround attempt)
Last that thing can be kinked.
Note: get a battery backup on that sump and must be in the sticks as I see it is propane energized.
Old 12/30/11, 6:57 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
No drip leg on the water heater either.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 12/30/11, 8:16 PM
KEVIN WOOD's Avatar
Wow! I can't believe how much I have learned from the MB today.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/31/11, 3:36 AM
KEVIN WOOD's Avatar
The T&P (Test and Pressure) valve on water heater needs a 3/4 threaded pipe to extend within 6 inches of floor for safety. (PVC is not approved for hot water use). I recommend repair by a qualified person. You must also have an air gap on the end of it to make sure it is not defective.
You will have to look close on the discharge pipe to make sure it is not approved for the discharge temperature before assuming that the PVC will not be OK.
Remember for all those that are new 150 PSI and 210 degrees F is needed stamped or written on the discharge pipe itself.
Nice comment from Rick!
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Flex hose connected to fireplace manifild....Need advice dnasser Inspecting HVAC Systems 3 8/28/11 10:28 AM
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
CPVC Connected to Water Heater krigler Plumbing Inspections 9 10/20/09 4:54 PM
Entran II Hose Class Action Suit jbushart Inspecting HVAC Systems 0 3/3/09 10:46 AM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
