Old 12/7/09, 10:59 PM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default Tpr Discharge line is PEX
Just wanted to know is pex line acceptable for use as the tpr discharge line on a water heater.
My thought is no because it is flexable. What are your thoughts please.tpr-discharge-line-cross-linked-polyethylene-100_0086.jpg
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America)
Old 12/7/09, 11:38 PM
Bob Elliott's Avatar
Default Re: Tpr Discharge line is PEX
Can it handle 200 degrees?
Check search we just did this one)
Old 12/7/09, 11:48 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
From the Plastic Pipe and Fittings Association (PPFA)
http://www.ppfahome.org/pex/faqpex.html
What are temperature limitations for PEX?
PEX tubing can be used up to 200° Fahrenheit for heating applications. For plumbing, PEX is limited to 180° F. Temperature limitations are always noted on the print line of the PEX tubing.. PEX systems are tested to and can be used with standard T and P relief valves that operate at 210” F and 150 psi.
Stephen Stanczyk
Old 12/7/09, 11:56 PM
Thanks Shephen I figured the temp was ok just not sure if the hot water made the PEX line like a garden hose and would spray everywhere instead of down. And the fitting on the picture is reduced in size and on any other application you cannot reduce the size less than 3/4.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 12/8/09, 2:02 AM
Joe Funderburk, CMI's Avatar
Per the IRC, any pipe approved for water distribution is approved for the TPR discharge, for the 14,000th time.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/8/09, 4:37 PM
Brian E. Kelly's Avatar
I must have told you a million times Joe, stop exaggerating.
Nice chart by the way, thanx.
Old 12/8/09, 10:44 PM
Paul Pendley Paul Pendley is offline
Is the inside diameter of the elbow the same as the inside diameter of the pex? If not I would think this would not be allowed.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 12/9/09, 12:15 AM
Paul this is not in response to your post
The fitting goes inside of the pex line so it would be smaller. So if its inside diameter of the fitting meets the requirments than it would be ok but it does not seem that anyone here seems to know.
I understand the pipe is ok for the temp that is why it is installed in the house on the hot water side of the plumbing. But the graph, chart or diagram does not show if the pipe will flex under high pressure spraying everybody that is in its path and with the elbow fitting being smaller that will help to increase the steam and high pressure water as it is coming out and spraying. have you ever seen a fire hose under pressure out of control and it isn't hot water. I under stand that the pex pipe is ok temp wise. But they dont show installation insturctions for the fly by night contractors that use what ever they have left over to save money. Ie In some timelines outlets were not grounded, wires were covered with cloth, afci were not heard of. Just because it states that pex is ok to be used with tpr discharge lines does not tell me that the set up is ok and proper or safe for that matter.
Mark
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 12/9/09, 1:34 AM
Why would it not be in response to my post? If the elbow is a smaller diameter then it would not be correct...in my opinion.
Pex is ok if its rated for that purpose but should be continious to the exterior without restrictive fittings I would think.
Paul Pendley
866-458-8516
Old 12/9/09, 1:35 AM
Not to mention the connection methods
Paul Pendley
866-458-8516
Old 12/9/09, 11:09 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
My thought is no because it is flexable. What are your thoughts please.Attachment 33739
Did it terminate within 4-6" of the ground in a downward fashion? Did they put a pvc or copper elbow at the end?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 12/9/09, 11:48 PM
No it had no fitting at the end and was tucked under the earthquake straps.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 11/12/10, 9:48 PM
bknowlton bknowlton is offline
I think it is not allowed to exit the wall to the exterior. It specifically states it cannot be used in contact with sunlight on most of the pipe I have seen, and is always broken off where the contractor has used it anyway. I would think it must have a copper elbow on the end that extends inside the wall to prevent sunlight from coming incontact with the PEX.
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/12/10, 10:41 PM
You are mistaken. Please post a copy of some literature from a manufacturer of pex that says it should not be exposed to daylight.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/12/10, 10:48 PM
There is nothing in the IRC that prohibits fittings. Can't speak for the UBC, but it's probably the same.
Theodore Roosevelt
Joe Funderburk, CMI
And another A/C condensate line discharge question bwilliams Inspecting HVAC Systems 4 11/6/08 11:20 PM
Slope of waste drain line. mlong Plumbing Inspections 5 4/23/08 9:54 PM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 1:43 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
