Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've never seen a set up like this and wondered if it's OK. There's no floor drain so they improvised.
If the end of the discharge pipe was open, and draining into a tub sink or something of that nature, I wouldn't make much about it. However since you can't see the discharge end, then the answer is no. (If it were leaking, how would anyone know? Not safe...)
PS. There may be other reasons too, but this one is enough for me to comment on it. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Thanks Mark, that's a good point. No way of really knowing if the end is in the sealant or the drain.
That also looks like 1/2" Aluminum. Should be 3/4 all the way to an observable open end as Mark said. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Yep, No reductions allowed. Just drain it to the floor with 3/4. Saftey item, but easily fixed.
Bill Corbett C.H.I. Magic City Inspections LLC InspectingtheUnexpected.com
James I agree. We should hold up signs, such as I give this one a
6.5 No unnecessary bends. Should go straight to the floor in 3/4". In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 4:27 PM |
| Air leak from floor drain | yolhovsky | Plumbing Inspections | 5 | 2/24/07 6:43 AM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
