Fellas
Can any of you tell me if you would call this out? I could not find any markings on the pipe, CPVC,PVC,etc. The piping was very flexible, don't know if it would meet the F at 100psi minimum req. Attachment 5744 Gary "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 8:43 AM.. |
Gary,
If there is no ID or an unknown material then yes it gets called to be replaced with approved known T&P piping, unless the plumber can provide a document to the contrary. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
This looks like the typical preformed drain tube you can get from many hardware stores. The pipe isn't glued to the male adapter. It has metal pins holding the assembly together. It may or may not be allowed in your jurisdiction.
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 4:27 PM |
| Air leak from floor drain | yolhovsky | Plumbing Inspections | 5 | 2/24/07 6:43 AM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
| Exposed drain and plumbers putty | tneumann | Plumbing Inspections | 19 | 4/27/06 10:57 PM |
| Washer Secondary Drain | roconnor | Plumbing Inspections | 7 | 4/2/06 1:02 PM |
