Havn't posted in a while but I couldn't resist this one. It gets worse, it's ran into and capped in the the attic.
| Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America) |
Well, yeah it should be capped... you try to avoid putting excess moisture into attic spaces.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
That's what i'll put in my report...
Huh...what are you going to put in your report? Hopefully not about capping it to keep moisture out of the attic....
By using the INACHI Message Board rule 114.5 subset 12 of section A...the usage of the emoticon has designated the previous reply by myself to be a smart-*** response. Tim has read and understood the almighty emoticon to deem it to be a joke and therefor, will not enter it into his report. Jeff oh....and Jeff Wicklander Corwick Home Services Join my business on Facebook
Oh...I see. My bad. Although keep in mind that there might actually be an inspector that is new to the business and promotes that business using a contractors license which is designated Landscaping. That inspector may not view the post as a joke and assume that the installation is correct. Just my 2 cents in dealing with the fly by nights we have up here right now in NorCal.
I actually laughed at your post and found it funny. Some things people and sub par contractors do amaze me. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Uphill, reduced in size and capped - Trifecta!
Only Lower would get an Upper.
| No secondary (pan) drain in Attic Okay per builder | mgault | Inspecting HVAC Systems | 14 | 1/30/09 8:38 AM |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/24/07 11:28 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
| K&T splice. | egarcia1 | Electrical Inspections | 13 | 2/3/07 6:36 AM |
