Old 3/9/06, 9:28 PM
Tony Siegert Tony Siegert is offline
Default TPR Drain up and out of crawl space???
Saw this today on a pre-listing inspection. Owner said a plumber installed???
Tony Siegert
SafeHome Inspection
Denver CO
NACHI05021692
Old 3/9/06, 9:56 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Default Re: TPR Drain up and out of crawl space???
Old 3/10/06, 12:03 AM
msaxton msaxton is offline
not good!
"If God was one of us, would he recommend a detailed analysis by a structural engineer for the world?"
Michael S. Saxton
http://www.duluthhomeinspections.com
Old 3/10/06, 8:26 AM
David P. Valley's Avatar
With this ridiculous installation, It wasn't a licensed plumber.
Old 3/10/06, 2:59 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
2003 IRC, Note specifically the bolded part:
P2803.6.1 Requirements of discharge pipe.
The outlet of a pressure relief valve, temperature relief valve or combination thereof, shall not be directly connected to the drainage system. The discharge from the relief valve shall be piped full size separately to the floor, to the outside of the building or to an indirect waste receptor located inside the building. In areas subject to freezing, the relief valve shall discharge through an air gap into an indirect waste receptor located within a heated space, or by other approved means. The discharge shall be installed in a manner that does not cause personal injury or property damage and that is readily observable by the building occupants. The discharge from a relief valve shall not be trapped. The diameter of the discharge piping shall not be less than the diameter of the relief valve outlet. The discharge pipe shall be installed so as to drain by gravity flow and shall terminate atmospherically not more than 6 inches (152 mm) above the floor. The outlet end of the discharge pipe shall not have a valve installed.
Knowledge is power but sharing knowledge brings peace!
Old 3/10/06, 5:54 PM
William Warner's Avatar
William Warner William Warner is offline
Note it as being PVC also. Won't hold the temps of a release.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 3/10/06, 5:56 PM
tneumann's Avatar
tneumann tneumann is offline
Looks like they need a sprinkler gut to fix that!
Old 3/10/06, 11:39 PM
Jay Moge's Avatar
it alway amazes me how much time and effort people will put into doing things wrong.
Old 3/11/06, 5:24 AM
Russel Ray's Avatar
Actually, some PVC will. Most PVC here has the temperature and pressure ratings printed on the pipe.
Old 3/11/06, 5:26 AM
Russel Ray's Avatar
It could have been an SOTB licensed plumber. I understand they are moving from here and Arizona into the Colorado and other Midwest areas.
Russel Ray's Avatar
Especially when they think it's right!
Old 3/11/06, 7:17 AM
It may be CPVC, but it is hard to tell for sure from the pic, which would be allowed around here but not installed like that.
Old 3/11/06, 9:55 AM
tneumann's Avatar
Hey@!%^$#!@
tneumann's Avatar
Hey@!%^$#!@
tneumann's Avatar
Hey!%^$#!@
