Old 12/17/07, 4:05 PM
efigueroa efigueroa is offline
Question TPR extension
I'm fairly new to the inspection business. I came across this TPR extension. I understand that most are either copper, galvanized, or CPVC. What is this made of. It was real flimsy and installed in a new home. Thanks.
Ed
Old 12/17/07, 4:20 PM
Michael Larson's Avatar
Default Re: TPR extension
Looks like PEX. Were there any markings on it?
Old 12/17/07, 4:21 PM
I didn't see any on it.
Old 12/17/07, 4:39 PM
The adapter fitting on the TPR looks like this TOOL was used to attach the PEX. The other method used is the use of crimp rings.
Old 12/17/07, 4:51 PM
klott's Avatar
klott klott is offline
If it doen't have a temp rating on it, I would call it out as possibly not being up to par, it's no good if it melts. JMO
Old 12/17/07, 4:57 PM
Jeffrey R. Pope's Avatar
I agree with Mike, it looks like PEX. Some jurisdictions allow this. The UPC, however, does not. Check your local codes.
If it has no visible markings, it should be replaced - period.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/17/07, 5:10 PM
Thanks for the info. I will check with local to find out what they allow and see if I could find out the plumbing company to see exactly what they put in. Once again. Thanks for the help.
Ed
Old 12/17/07, 6:26 PM
Originally Posted by jpope
I agree with Mike, it looks like PEX. Some jurisdictions allow this. The UPC, however, does not. Check you local codes.
good points Jeff.
Here are the marking requirements for ALL PEX tubing from PPFA
MARKING
PEX tubing must be labeled as follows:
  1. The manufacturer's name or trademark
  2. The standard to which it conforms (ASTM F876, F877, AWWA C904 and/or CSA B137.5)
  3. Tube size and CTS
  4. Material designation code (PEX0006)
  5. Pressure/temperature rating(s)
  6. SDR9
  7. If the tubing is for potable water, a laboratory seal or mark attesting to suitability for potable water
  8. ASTM fittings designations approved for use by the tubing manufacturer
The marking interval is required to be no more than five feet long.
Old 12/17/07, 6:33 PM
Jeffrey R. Jonas's Avatar
Looks like PEX.
Where PEX is allowed by the AHD, and since it is a non-rigid pipe, would it also be required to have some sort of clamping device to prevent it from "whipping" in the event the TPR valve activates?
Old 12/18/07, 12:03 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I don't know about other jurisdictions, but the TPR discharge line is supposed to be rigid.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 12/18/07, 12:22 AM
tdietrich1's Avatar
Is that a puddle to the left of the tank?
tom
Old 12/19/07, 9:57 AM
This was my concern overall.
Tom,
That wasn't water in the pan below the unit. It was the coating scratched from the pan.
Old 12/19/07, 10:11 AM
I spoke to the local code enforcement office and they just told me that the only PEX they allow is PEX a, which should be marked on it. Also, if PEX, it should be strapped to the unit. I think that said it all. Thanks alot, Mike, Jeff, and Jack.
Ed
Old 12/19/07, 1:02 PM
tdietrich1's Avatar
Strapping it to the unit makes sense. Once it heats up, it might become soft and look like a wacky kids sprinkler.
Refresh my memory, is the 'lack' of a 'drip loop/sediment trap' now not a problem?
tom
Old 12/19/07, 6:53 PM
tom
Not in the original question, but yes I always call it out when the drop/dirt leg is missing.
Garage door opener extension cord cfolsom Electrical Inspections 4 11/22/07 12:49 PM
Extension Cord Wiring psmothers Electrical Inspections 1 6/4/06 9:11 PM
Joe F, update? jtedesco1 Electrical Inspections 54 4/10/06 10:35 AM
