Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 7/8/06, 6:04 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default TPR has PEX2 for discharge piping
New home construction - PEX 2 used for TPR discharge piping at tank. On the exterior it was plumbed with copper. From what I understand the discharge piping can only be galvanized steel, hard drawn copper or cpvc.
First time I have seen this setup. Any comments would be appreciated.
Also foam was used around flue. I dont think foam can be used for this purpose. Any comments would be appreciated.
tpr-has-pex2-discharge-piping-100_7077.jpg   tpr-has-pex2-discharge-piping-100_7078.jpg   tpr-has-pex2-discharge-piping-100_7076.jpg
Old 7/9/06, 12:04 AM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
Default Re: TPR has PEX2 for discharge piping
James,
I don't have the IRC handy...but my understanding is the discharge pipe can be the following:
* Hard Drawn Copper, CPVC, polybutylene or steel......
polybutylene...imagine that......well thats because the pipe would be fine...but the fitting would blow to heck...thehehe
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
Old 7/9/06, 12:44 AM
Joe Funderburk, CMI's Avatar
The requirements for pipe material are at IRC P2803.6.1: "Be constructed of those materials listed in Section P2904.5 or materials tested, rated and approved for such use in accordance with ASME A112.4.1."
A screen shot of the table is attached, and PEX is on the list. (Think about it, if PEX is suitable for distribution of hot water, why not as a discharge for it? About the fittings, don't they withstand all the pressure in the system under normal conditions and wouldn't you think there is a pretty high safety factor built in? I don't know the limitations on the fittings, but the table seems to be clear.)
P2904-05.pdf
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/9/06, 8:46 AM
Russel Ray's Avatar
PEX is acceptable here.
  • Need a positive networking site? Click here to join Active Rain, a networking community of over 140,000 real estate professionals helping others.
  • NACHI 2005 U.S. Member of the Year
Old 7/9/06, 10:04 AM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
I personally think the TPR discharge piping should be rated for the same temperature and pressure that pops the valve. Most water heaters have valves that open at 150 psi, or 212 degrees. Is pex or cpvc rated that high?
Stu
Old 7/9/06, 12:19 PM
Russel Ray's Avatar
Stu
If the drain pipe were closed, I would agree with you. But with an open pipe, it won't have to take the pressure or the temperature for any extended period of time, usually something on the order of seconds. If you look at pressure and temperature ratings, the rating tests usually take place over minutes or hours.
Old 7/9/06, 1:35 PM
Piping is rated at 1000 psi at 180 degrees. I got that off the pex markings on the piping.
Old 7/9/06, 3:46 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
Joe,
Where did you get your copy of the IRC in pdf form?
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 7/9/06, 4:01 PM
what do you guys think about what appears to be can insulation around the vent in picture 3. Is this acceptable. Is this fire stop? (see first post)
Old 7/9/06, 4:41 PM
Russel Ray's Avatar
There is some foam that is rated for high temperatures, but could you verify that the foam used is the high-rated foam?
Old 7/9/06, 11:21 PM
Originally Posted by psmothers
Joe,
ecodes.biz. Paid $54.50 to download the PDF file of the entire 2006 IRC.
Joe Funderburk, CMI
Old 7/10/06, 12:14 AM
Nice Joe
http://www.ecodes.biz/product.cfm?ca...1&cat_type=pay
"Never ever threaten anyone in Camoflage"
Tim Wilson
"Not everyone follows the same path"
Governor Sanford, musings on the Appalachian Trail
Help - Polybutylene Pipes Rick G Plumbing 39 2/12/09 9:16 AM
Bonding both hot and hold supply pipes kshepard Plumbing 22 5/4/08 9:00 AM
Do you put polybutylene in the Summary? jfunderburk Plumbing 36 11/27/07 12:56 AM
Bonding Piping 101....Good To Know ! pabernathy Electrical 37 4/28/07 12:25 PM
plastic piping? Scott Schultz Plumbing 5 3/28/07 2:40 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
