How would you report this one? Pipe has high temp/pressure rating but vent up and to outside of house. "Drip leg" for.....
TPR valve extension piping has been reduced in size and runs uphill...recommend repairs by qualified plumber for enhanced safety.
I can't tell what is on the bottom of the pipe. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
(up flow) "Inspector noted the TPRV drain piping on the water heater not installed in a way that will facilitate drainage by gravity per national standards. Its installed going up. We recommend a qualified plumber review for determination and certification that the current install does not inhibit its proper function and corrective repairs as needed."
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
TPR discharge piping was installed by an idiot that doesn't have a friggen clue. . .
What is this "EverKleen" thing? Is that just a curved dip tube to keep the sediment mixed up or if there some other fancy gizmo? |
jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think I'll borrow that for mine!! |
Jeff's comment is in my boilerplate
I linked the mfg install instructions in my report and recommended a lic plumber inspect and repair as needed. Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
The water heater drain line improperly runs uphill and can be a safety hazard. Have a competent & licensed plumber repipe it safely and in the proper manner.
Hi to all,
I think this is a great idea, and would save all of those pesky leaks onto the floor, I believe that TPR extensions should be run verticaly up through the roof and fitted with a steam whistle at their termination Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Steam whistle! LOL!!
Was that the current owner will be seriously scolded or is that scalded to the current method if installation if valve failure occurs
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| 1 condensate line...... | Scott Schultz | Inspecting HVAC Systems | 2 | 11/4/07 6:18 AM |
| Gas line protection | jlybolt | Exterior Inspections | 2 | 5/30/07 12:18 PM |
| Water line repair program. | dmacy | Plumbing Inspections | 2 | 1/10/07 10:22 AM |
| Size of supply line | aobrien | Inspecting HVAC Systems | 7 | 1/2/07 12:40 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
