Old 4/17/07, 4:32 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default TPR tapped into cold
Has anyone seen this set up before?
tpr-tapped-into-cold-2001-tpr.jpg   tpr-tapped-into-cold-picture-002-small-.jpg.jpg
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 4/17/07, 4:38 PM
gkoehl's Avatar
gkoehl gkoehl is offline
Default Re: TPR tapped into cold
Thankfully- NO
What in the world is the cold water loop for?
George Koehl
Collinsville, TX
TREC# 9435
NACHI ID: 06092190
InTex Inspections
Old 4/17/07, 4:40 PM
Shawn Rowe's Avatar
Good question...two water heaters set up the same way. I can't figure out the installation logic.
Shawn Rowe, CMI
Old 4/17/07, 5:12 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
The logic was faulty - recommend repairs by a licensed plumbing contractor...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 4/17/07, 6:11 PM
tdietrich1's Avatar
Looks like M.C. Escher did some plumbing too.
tom
Old 4/17/07, 7:41 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thats an extreme recycling program
Old 4/17/07, 8:43 PM
Michael Larson's Avatar
WAtts pressure relief valve. It takes the place of an expansion tank. It is installed correctly.
See this LINK
Old 4/18/07, 1:38 AM
Russel Ray's Avatar
Oh, that was a margarita ASNR.
Old 4/18/07, 1:41 AM
Russel Ray's Avatar
I think Michael's got it right.
Old 4/18/07, 9:29 AM
dchew dchew is offline
Wouldn't been easier and better to install a pressure regulator at the outside shutoff valve? The water heaters are protected, but the rest of the plumbing is see the higher pressure in the line.
Old 4/18/07, 9:45 AM
The whole system is protected. The hot and cold side are not isolated from each other. They meet in the water heater tank.
Old 4/18/07, 11:07 AM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
See this LINK
The installation instruction on the watts valve above does not show this configuration...or at least maybe I missed it.
Any how the question I have is how would this work?
We can not see from the picture where the TPR drain line goes to, but if it is tee'd into a supply line, then there is nothing to keep the water from flowing out of the drain line. Obviously I am missing something.
Old 4/18/07, 12:01 PM
tdietrich1's Avatar
I think I understand what you mean. I don't argue this is a pressure only relief, but I wonder if its installation is correct. Meaning, whey do both the tpr and the pr both connect to the same tail? Is this OK?
tom
Old 4/18/07, 12:37 PM
That is allowed, and common in this jurisdiction. The expansion valve takes the place of the expansion tank and drains into the overflow pipe from the TPR valve.
Until the AHJ writes it up here as a faulty install, I won't call it out.
Abraham Lincoln
Old 4/18/07, 12:58 PM
See this LINK
Looks closest to the model 3L which is for Gas water heaters with a seperate gas shutoff to protect from overtemps.(not an exact match)
Looks like a standard TPV valve plumbed back into the cold side. I can't see the tail below the upward 90 but I've never seen this configuration.
Still would defer it...
- Mike
NACHI05040682
(843) 442-9755
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 10:04 AM
TPR Valve on Cold water pipe lewens Plumbing Inspections 11 3/5/07 5:53 PM
cold climates: insulating floors w/plumbing above cold crawlspaces kshepard Plumbing Inspections 6 9/26/06 12:09 AM
Hot water heater Hot and Cold hookup phughes Plumbing Inspections 20 5/11/06 2:04 AM
