Old 5/20/07, 1:52 PM
Andrew Cox Andrew Cox is offline
Default TPR valve
Just finished with this home - it's in great shape, but found this...that's the top of an electric water heater. This is as close as I could get because the owners have storage shelves in front of it. How can I report this... ?
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 5/20/07, 2:14 PM
Michael Larson's Avatar
Default Re: TPR valve
Do you have a question?
Old 5/20/07, 2:15 PM
Sorry, I was in the process of editing my post - I went back and realized it didn't make sense. Any suggestions for wording the report?
Andy Cox
Kissimmee, FL
Old 5/20/07, 2:19 PM
I see a nomal install if the overpressure device at the top is permitted in your area. That device takes the place of a bladder type expansion tank.
Old 5/20/07, 2:23 PM
OK - I haven't seen this before. I just wasn't sure if it could be tied to the TPR outlet.
Andy Cox
Kissimmee, FL
Old 5/20/07, 2:27 PM
More information here
Old 5/20/07, 2:46 PM
That helps alot - Thanks for the info!
Andy Cox
Kissimmee, FL
Old 5/20/07, 5:36 PM
Jeffrey R. Pope's Avatar
The TPR discharge must be separate from any other system. It appears to be tied into the other PR valve with a T-fitting.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/20/07, 6:10 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
I agree, I thought that TPR discharge had to go directly to the floor with no T-fittings at all.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 5/20/07, 6:49 PM
Not necessarily "to the floor," but no T-fittings are allowed in the discharge piping. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/20/07, 7:04 PM
Yes, I skipped a bit of info didn't I.
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 5/20/07, 7:14 PM
mthomas2 mthomas2 is offline
Direct link to the Watts installation instructions:
http://www.watts.com/pdf/1910868.pdf
Old 5/20/07, 7:15 PM
tdietrich1's Avatar
Not to beat you up, just like to have references, do you remember one? See "common sense" is ofen not good enough.
tom
Old 5/20/07, 7:39 PM
They may drain to outside. It should still terminate < or = to 6", or to at drain pan.
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 5/20/07, 11:37 PM
T-fittings are not specifically addressed, so the intent is somewhat subject to interpretation.
P2803.6.1 states "The discharge from the relief valve shall be piped full size separately to the floor, to the outside of the building or to an indirect waste receptor located inside the building."
So I guess one would have to ask, what is the purpose of a T-fitting?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Mixing valve question cmettel Plumbing Inspections 2 6/17/07 10:03 PM
Backwater valve in new homes? ccrooker Canadian Inspectors 16 11/28/06 7:47 AM
Water Heater Pressure Valve wrosario Plumbing Inspections 3 7/7/06 7:27 PM
Pool inspections/ valve check dbucknavich Ancillary Inspection Services & Additional Topics 1 6/21/06 3:33 PM
Manifold connections, mixing valve question jclark1 Plumbing Inspections 14 6/15/06 10:46 PM
