Old 3/2/07, 3:52 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default TPR Valve on Cold water pipe
There it was on an old electric water heater. The cold water entered from the bottom of the tank and the TPR valve was about half way up the tank on the cold water pipe. Seems to me that this is rather a useless place to put a TPR valve. What say the plumbing gurus.
Larry
Old 3/2/07, 3:56 PM
Default Re: TPR Valve on Cold water pipe
Larry
Temperature ain't gonna reach the "pop-off" stage...it belongs on the hot water side. The tank is usually equipped with fittings for the TPR on the top and the side--both into the hot water.
Old 3/2/07, 11:06 PM
Barry Adair's Avatar
Could it have been a pressure only relief valve?
Was there a TNPV, also?
http://www.watts.com/pro/_products_s...=64&parCat=293
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/3/07, 3:23 AM
Roy D. Cooke, Sr's Avatar
Larry
I have seen where they have put tr valves on the cold water years ago but never TPRs .
The difference is the tr does not have the little leaver to test the valve for hard water build up ,
Jae is correct the TPR must be installed on the hot water out let.
Regardless it should be written up as incorrect.
Roy Cooke
Old 3/3/07, 10:42 AM
tneumann's Avatar
tneumann tneumann is offline
Know what I mean?...
Old 3/3/07, 11:23 AM
Mike Nelson's Avatar
Mike Nelson Mike Nelson is offline
I recently came across a system where the whole system was protected by a tpr valve placed outside, it came with an auto shutoff for the gas at the unit, strange but kinda cool.
Mike Nelson CPI, CMI
NYS License # 16000005765
(Just because you understand how something is built, in no way prepares you for the innumerable insults a human being can heap upon a domicile)
Old 3/3/07, 11:44 AM
Michael Larson's Avatar
Hi Mike,
You keep tantalizing us with descriptions but no pictures.
Sure would like to see what you are describing.
Old 3/5/07, 9:53 AM
Originally Posted by mlarson
Hi Mike,
Sounds like a WAGS http://www.wagsvalve.com/
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 3/5/07, 10:09 AM
Thanks Barry. I haven't seen one of these before.
Old 3/5/07, 12:31 PM
Brian E. Kelly's Avatar
Pre
ssure & Temperature-Relief Line
  • Terminate outside 6in.-24in. from ground point down [608.5] [3408.5.2]
  • 3/4in. min., no trap, no reduction, no thread on end [608.5] [3408.5.4.1]
  • If Watts 210 valve is used, pressure-relief valve to be installed [manu.] [3408.5.5]
When a water heater is below grade, a Watts 210-style- temperature relief gas shutoff may be used in lieu of the required integral temperature and pressure-relief valve so long as it is installed in conjunction with an approved pressure relief device that relieves outside the building. As with any "approved" device, these must be installed to manufacturer's specifications.
Watts 210 valve perhaps?
Old 3/5/07, 4:53 PM
yeah, yeah, that's the ticket!!
Old 3/5/07, 4:53 PM
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
small valve on cold water supply ahead of water heater? Walt Hoffman Plumbing Inspections 6 1/23/06 7:44 AM
