Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 6/21/09, 11:32 AM
Richard A. Moran, 2nd Richard A. Moran, 2nd is offline
Default TPR valve outlet pipe.
I did a REO inspection yesterday and found this [see pic]. I noted that the pipe should not be connected directly into the sewer drain and should end at about 6" from the floor and be visible. My code check says something about indirect waste is OK. Is indirect waste a sump pump well?
Dick Moran
Dick Moran
True Blue Home Inspections
A Div of RAM2, LLC.
Clarksville, MD
240-832-6838
MD HI License 29927
Find an InterNACHI certified Ohio Home Inspector (and anywhere else in North America)
Old 6/21/09, 1:39 PM
Default Re: TPR valve outlet pipe.
http://www.nachi.org/forum/f22/defin...receptor-1762/
Jeff
Jeff Wicklander
Corwick Home Services
224-715-0457
Old 6/21/09, 2:42 PM
Chuck Evans's Avatar
Indirect waste receptor requires an air gap so that you can visually see that the TPR is discharging. An example would be a floor drain with a trap.
You were correct in stating that this configuration is improper.
Identify ABS defective pipe mcyr Plumbing 6 1/29/09 7:39 PM
Pellet stove help chellickson General Inspection Discussion 22 8/10/08 5:41 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues 50 4/20/08 2:26 AM
Do you put polybutylene in the Summary? jfunderburk Plumbing 36 11/27/07 12:56 AM
TPR valve acox Plumbing 19 5/27/07 1:36 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
