Old 11/30/07, 4:38 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default TPV PEX routing
Would you fuss much about this PEX being routed just beneath the access cover? I'm tempted to...
If so, why?
The plumber did save himself one more elbow and crimp one less joint...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/30/07, 4:40 PM
Michael Larson's Avatar
Default Re: TPV PEX routing
Well it doesn't obstruct but could have been better.
Old 11/30/07, 4:41 PM
Jeffrey R. Jonas's Avatar
Looks as if the PEX is touching the access cover...over time this will wear the PEX (from water surge/vibration) causing a leak.
Old 11/30/07, 4:42 PM
It's not a pressurized line but from the TPR, I assume.
Old 11/30/07, 4:44 PM
Is PEX allowed on a TPR ???
Old 11/30/07, 4:46 PM
PEX is fine. CPVC is fine. PVC is not
Michael Larson
Hudson, WI
Old 11/30/07, 4:47 PM
TPR Valve piping, yes...
- Mike
NACHI05040682
(843) 442-9755
PEX is okay...
- Mike
NACHI05040682
(843) 442-9755
Old 11/30/07, 4:48 PM
Thanks, I don't see PEX very often, and have never seen it on a TPR.
Old 11/30/07, 4:50 PM
Michael, you're too quick...
Yeah, it might rub, yeah it touches, yeah it might eventually rub a hole in the top (which should never be a leak....)
I just think it's poor workmanship... trying to save an elbow and two crimps...
- Mike
NACHI05040682
(843) 442-9755
Old 11/30/07, 4:56 PM
Agreed
Old 11/30/07, 7:54 PM
Michael
Is the Pex a 3/4" required size, or is smaller, as it appears to be. I probably would worry that the cover may fall off, be removed and left off permanantly, etc. allowing enough heat to escape, allowing for meltdown over time. Not likely, be I guess it could happen.
Old 12/4/07, 8:31 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
The TPR line has to be full size from valve to end.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Plumbing vent Routing Question kweiss Plumbing Inspections 7 11/1/06 9:57 PM
gutter routing nbhi Exterior Inspections 7 8/22/06 1:09 AM
