Is this material allowed for the use of a drainage trap. It looks to be OK. Normally see either PVC or stainless.
Hi Dave
I may be wrong but isn't that the top part of washing machine discharge hose?? It sure is not acceptable in that location, I am guessing that they were having difficulty getting standard rigid piping to fit so threw that hose in there. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
jinvernizzi is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks
Is this acceptable with the IRC & UPC plumbing codes. Seems like a decent product. Nice web link. I would say you got it. Here is a question that was in a MR. FIX IT How to operate your home. Q.How many fixtures can be served by a 1/2 inch copper line? I would think this would depend on the IRC & UPC tables. Pressure & length of pipe would determine. Am I correct. |
Hi to all,
Good one John, I have never seen that fitting thanks for the link. I also wonder whether it is code compliant Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Nice link John, thanks.
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
I believe it has an ICC Legacy report attached, so it appears to be legit! See: http://www.icc-es.org/reports/pdf_files/BNBC/97-29.pdf |
Home Depot sells them here but I think theirs is black.
Paul Hinsperger Hinsperger Inspection Services Ltd Orangeville Ontario www.hinsperger.com |
| Trap primer valve | dmacy | Plumbing Inspections | 2 | 12/27/06 2:21 PM |
| Potable Water Line to Trap | jcooper2 | Plumbing Inspections | 9 | 11/1/06 1:17 AM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/15/06 12:00 AM |
| Grease Trap / Drum Trap | David White | Plumbing Inspections | 1 | 2/7/06 6:41 PM |
