Today's inspection had a deep sink. A really deep sink that apparently the plumber wasn't expecting during the rough in. I simply said the drain should be replumbed. I am posting the photo for your enjoyment. What would you call this trap?
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is this a PS trap?
Brian, did that abortion actually work?
FUBAR would be the name for it. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
5 trips to the hardware store.
That would be called a deep seal trap.
Yeah, the sink drained fine but that don't make it right. This was built in from day one and the home is 8 years old. I told the purchaser that if he doesn't fix it and his wife ever drops something that needs to be retrieved from the drain that it will still be in the Ptrap but he is going to need a tub that will hold a gallon underneath when he dismantles it.
Luckily no seals where injured in photography of this episode.
One would almost think that the amount of head pressure needed to make it work, water would be going in the pig first.
I see nothing but dumba-s.
That dishwasher is a bacteria trap. Why? Look at the disposal drain and you will see how that food would fly back into the dishwasher. Around here you are not allowed to hook up a dishwasher to a disposal to begin with. Remember water seeks its own level. |
Brian ,the disposal provides centrifical force enough to possibly contaminate the clean dishes.
Where I am ,air gaps are code, though I will approve of the reverse trap unless attached to a disposal. |
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| Trap Primer Question | jallingham | Plumbing Inspections | 5 | 2/15/08 7:36 PM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/14/06 11:00 PM |
| Grease Trap / Drum Trap | David White | Plumbing Inspections | 1 | 2/7/06 5:41 PM |
