Old 10/3/07, 4:16 PM
Default Trap Configuration??
Need some assistance with this configuration. Owner decided to move the disposal from the left sink to the right sink. So the plumber added a sanitary T on the left p-trap. I looks very much like an S-Trap configuration.
Comments or suggestions?
Kevin
Old 10/3/07, 4:26 PM
tdietrich1's Avatar
Default Re: Trap Configuration??
If I had to guess based on that photo, it does look like an s-trap(actually 2).
tom
Old 10/3/07, 4:30 PM
Dale Duffy's Avatar
Here is a S-Trap.
Old 10/3/07, 4:35 PM
Originally Posted by dduffy
Here is a S-Trap.
That's a good picture, Dale. What's you opinion on this "A-typical" configuration?
Kev
Old 10/3/07, 4:39 PM
Dale Duffy's Avatar
Kev
Kevin if it drained fine I doubt by looking at the picture I would say much of anything, "except it appears to be done by an amateur and if drainage problems occur in the future have a licensed plumber install everything pretty like".........
Old 10/3/07, 4:40 PM
Jeffrey R. Pope's Avatar
The traps must be at the same elevation, which they are not.
The upper drain-line will siphon the contents of the lower trap. The whole thing is a wreck. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/3/07, 4:43 PM
Dale Duffy's Avatar
Jeff
How are they going to siphon the contents from each other when their connected to two different openings?
Old 10/3/07, 4:46 PM
Thanks Dale and Jeff!!
Kev
Old 10/3/07, 4:49 PM
Jeff
Dale,
I'm sure Jeff will answer, but here was my original take. The water flowing down the waste pipe for the "right" sink could cause the siphon water out of the "left" trap that is lower than the "right" trap and is connected below with a sanitary T.
That is my take, anyways. I wrote it up as being "a-typical" and called for further evaluation by a licensed plumber.
Kev
Old 10/3/07, 4:53 PM
Dale Duffy's Avatar
Dale,
Kev
Old 10/3/07, 5:11 PM
Dale Duffy's Avatar
Kevin...besides the ugly plumbing, you have about the best looking website I think I have ever seen..!
Old 10/3/07, 5:16 PM
Thank You
Old 10/3/07, 5:29 PM
Dale Duffy's Avatar
Thank You
Off the ugly plumbing topic .........
Kevin....could you give me a rough est. how much more money your making with the IR cam?
Are you doing any just simply IR inspections?
Damn I want one of those cams but keep wondering if it will pay for itself here, since we do lack rain now and then......
Old 10/3/07, 6:00 PM
Since March of this year, I have averaged just over 1,000 a month from my ITI services.
I have had a few requests for stand alone IR Inspections, but mostly ad-on's to a general HI.
If I were you, I would take the plunge now rather than waiting. In about 5-7 years (maybe sooner) most inspectors will have an IR camera in thier tool bag. The sooner you get into doing it, the more money you are going to make and you will set yourself apart from your compitition.
Here is what I've been charging:
1. ITI General Scan (ad on to HI): 79.00
2. ITI Electrical Survey: 99.00
3. ITI Moisture Survey: 99.00
4. ITI Energy Survey: 129.00
5. Home Tune-uP with ITI Energy Survey w/Inspection: 278.00
6. Home Tune-uP with ITI Energy Survey without/Inspection: 428.00
By far the most popular is the General ITI Scan. I bring the camera to every inspection and offer my clients a brief demo asking them if they want to add the general scan. Most say "yes" on the spot.
-Kevin
Old 10/3/07, 7:36 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Same here, extreme drought and now they are saying there could be a watering ban until middle of 2008.
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 12:17 AM
Trap Cover on vent stack? hspinnler Plumbing Inspections 9 10/8/06 10:35 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
