Hey guys is this proper in the crawl space, this particular trap? you can defiantly see its clogged and overflowing.
This pic is under the shower in the crawl Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks OK to me.
It is pretty common for shower drains to leak. I guess it is due to the flexing of the shower when people stand there. |
Even with that kind of trap??
I don't think it matters that the trap goes 'backwards' (if that is what you think the issue might be). The main thing to look for is the depth, which appears to be less than the 4 inch maximum.
Hey Troy,
What is that trap to? Is it a shower, floor drain, or commode? In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Jack it is to the shower
Don't normally see a 3" trap for shower in ABS. The leak should not be there (plastic usually flexes enough to cover shower base). There direction of the trap is not important, but the leak is.
The leak appears to have been from some past issues no leakage present at time of inspection. For some reason I just had a brain fart and it didn't look right.
OK, it doesn't NEED a cleanout, but does it have a vent? Here are a couple of technical illustrations.
Vented yes thanks for the help
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 8:43 PM |
| Trap Primer Question | jallingham | Plumbing Inspections | 5 | 2/15/08 8:36 PM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/15/06 12:00 AM |
