Old 7/24/07, 7:50 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Trap help
I have to be honest, I don't see alot of non p-traps. This is an S-trap of course, but the drainage was fine. Should I ask for replacement anyway and why?
Old 7/24/07, 7:55 PM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Trap help
Because it will let sewer gas escape.
Old 7/24/07, 8:10 PM
Jeffrey R. Pope's Avatar
Because it's an "S" trap.
It's not about drainage. It's about health and safety. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/24/07, 8:33 PM
And health and safety win every time. Thanks.
Old 7/25/07, 11:50 PM
jcundiff's Avatar
jcundiff jcundiff is offline
Please Note: jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sometimes it is a tough call- especially when the waste inlet is in the floor. In this case it looks like they could have used a sanitary 90 and a p trap. I'd write it.
Old 7/26/07, 12:48 AM
Charley L. Bottger's Avatar
Not a tough call for me I write them all had three in the same house on Monday. S-traps are notorious for siphoning the water dry. Strictly a NO NO
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 7/28/07, 8:45 PM
lfoster's Avatar
lfoster lfoster is offline
What about adding an AAV like a mobile hole does? Would be OK then, right?
Old 7/28/07, 11:33 PM
mdiplock's Avatar
mdiplock mdiplock is offline
.....and then there is always the infamous S - P trap. Thought I would put this up for a chuckle. Of course I wrote it up as WRONG, Wrong, wrong and just plain silly. trap-help-2007_071030emerick0008.jpg
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself"
Regards,
Mark
Old 7/29/07, 2:09 AM
No, that does not make up for an improper trap. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/29/07, 8:28 AM
Barry Adair's Avatar
Linda,
I know you are only trying to be helpful but please be careful not to design or prescribe alterations or repairs to any systems as part of your inspection process.
ALWAYS defer these to the specialized qualified professional contractor and allow them to design the correct repair for the situations you encounter.
BTW here are the AAV codes
http://www.studor.com/codes.htm
Are you certain they would be allowed in your area?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/29/07, 9:05 AM
rwand1 rwand1 is offline
How is this trap a health and safety issue?
It may hold water in the trap and it may function properly.
If anything in my opinion it is not a safety issue, and perhaps not even a health concern, without actual testing.
Old 7/29/07, 9:26 AM
Raymond,
CDC has a different spin then you on this http://www.cdc.gov/nceh/publications...sing/cha09.htm
Traps
A plumbing trap is a device used in a waste system to prevent the passage of sewer gas into the structure and yet not hinder the fixture’s discharge to any great extent. All fixtures connected to a household plumbing system should have a trap installed in the line. The effects of sewer gases on the human body are well known; many of the gases are extremely harmful. In addition, certain sewer gases are explosive.
P-trap. The most commonly used trap is the P-trap (Figure 9.6). The depth of the seal in a trap is usually 2 inches. A deep seal trap has a 4-inch seal.
As mentioned earlier, the purpose of a trap is to seal out sewer gases from the structure. Because a plumbing system is subject to wide variations in flow, and this flow originates in many different sections of the system, pressures vary widely in the waste lines. These pressure differences tend to remove the water seal in the trap. The waste system must be properly vented to prevent the traps from siphoning dry, thus losing their water seal and allowing gas from the sewer into the building.
Objectionable Traps. The S-trap and the ¾ S-trap (Figure 9.7) should not be used in plumbing installations. They are almost impossible to ventilate properly, and the ¾ S-trap forms a perfect siphon. Mechanical traps were introduced to counteract this problem. It has been found, however, that the corrosive liquids flowing in the system corrode or jam these mechanical traps. For this reason, most plumbing codes prohibit mechanical traps.
The bag trap, an extreme form of S-trap, is seldom found. Figure 9.7 also shows this type of S-trap.
Traps are used only to prevent the escape of sewer gas into the structure. They do not compensate for pressure variations. Only proper venting will eliminate pressure problems.
Bold is mine and I agree with these staments.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 7/29/07, 9:28 AM
Michael Larson's Avatar
Posibility of loss of trap seal and allowing sewer gas into the home.
Minnesota Rules, Table of Chapters
Table of contents for Chapter 4715
4715.0960 TRAPS PROHIBITED.
No form of trap which depends for its seal upon the action
of movable parts or concealed interior partitions shall be used.
Full "S" traps, bell traps, and crown vented traps, are
prohibited.
Traps shall not be made up with fittings, unless authorized
by the administrative authority.
Water-cooled grease traps are prohibited.
No fixture shall be double-trapped.
Drum traps shall be installed only when permitted by the
administrative authority for special conditions (laboratory
tables, dental chairs, etc.).
STAT AUTH: MS s 326.37 to 326.45
Current as of 02/05/04
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 7/29/07, 9:36 AM
Thats great info, but I fail to see how its a safety issue.
Should it be replaced? I guess that depends on testing and the complete set up of the waste system, venting, et. cetera. Will home purchaser tear it out, or will it nix a deal considerate of the age of the system?
Old 7/29/07, 9:38 AM
Well the next question is how old is the house? If its existing and predates current code, is it an issue?
Trap primer valve dmacy Plumbing Inspections 2 12/27/06 2:21 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 1:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 6:41 PM
