Old 2/1/09, 1:32 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Trap location
Does a trap need to be directly below the fixture or can it connect with an arm as in the photo?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 2/1/09, 1:54 PM
Dale Duffy's Avatar
Default Re: Trap location
The trap can be located as pictured Bill....
Old 2/1/09, 2:00 PM
Bill Smith's Avatar
Excellent Dale - I just wanted to double check. Thanks for the reply.
Go Cards!
631-434-5200
Old 2/1/09, 3:40 PM
wsiegel wsiegel is offline
That dishwasher hose need to be raised and connected under the countertop.
Old 2/1/09, 3:41 PM
jkogel jkogel is offline
Go Cards!
If I'm unsure, I fall back on describing it.
It is unconventional plumbing, appears to be adequate, not leaking/smelling, handy washcloth rack, vulnerable to damage from shoving stuff around, possibly amateur handiwork, repair/replace if leaking occurs.
John Kogel
www.allsafehome.ca
Old 2/1/09, 3:44 PM
Bob Elliott's Avatar
Yeah this came up recently.
Whats the purpose of a trap other than to keep sewer gas from entering off the vent pipe-waste stack.
Distance should not matter as long as it is between the drain opening and vent,though vent distance is another subject.
Old 2/2/09, 6:25 AM
Bill Smith's Avatar
In this area that is the standard method of connecting dishwashers. It might not be right, but I got tired of calling it out only to be told later I was wrong.
631-434-5200
Old 2/2/09, 2:47 PM
At least the dishwasher is not connected like the one I saw last week !! (It's that copper line near the floor)
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 2/2/09, 3:03 PM
Not only getting cross -contamination,but is stressing the pump.
Old 2/2/09, 3:37 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Give them the manufacturers instalation instructions next time someone tells you that you are wrong about this.
They can argue with the people who designed and built it.
BTW, who was it that was saing you were wrong?
Old 2/2/09, 6:07 PM
Bill Smith's Avatar
Local Plumbers, Code Officials, etc - It's just how it's done here. Not worth the discussion
631-434-5200
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 7:36 PM
W/M drain trap below the floor rbrady Plumbing Inspections 3 1/22/08 11:51 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
