Old 11/1/10, 3:39 PM
Default Trap Primer
I'm told there is a device for installation in floor drains that eliminates the need for a trap primer. Lets water in but no sewer gases out. Is there such a thing?
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/1/10, 3:56 PM
Michael R. Boyett's Avatar
Default Re: Trap Primer
http://thesureseal.com/index.php
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 11/1/10, 4:22 PM
Thanks Michael, hadn't come across that before.
Old 11/1/10, 4:55 PM
That must be it. Thanks.
Old 11/1/10, 10:27 PM
Banned
Another system is made by DRANJER
http://www.dranjer.ca/pages/about.htm
Another system has a small rubber ball that is held up against a rim by a small spring to form an air seal. When water runs to sit on the ball, the extra weight allows the ball to sink a bit, allowing the water to drain. After the water drains, the balls rises to form the seal again.
Condensation Drain line question acassady Inspecting HVAC Systems 25 2/26/12 11:40 AM
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 7:36 PM
Trap primer valve dmacy Plumbing Inspections 2 12/27/06 1:21 PM
Trap primer lschmid Plumbing Inspections 4 4/14/06 11:03 PM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
