I inspect mainly newer homes and of course they all have trap primers going into the basement floor. Sometimes the small primer lines go into the floor quite a distance from the floor drain. Usually they are beside a stack.
If the purpose of the trap primer is to keep the floor drain trap full, wouldn't they have to enter right at the floor drain. Obviously they are not there to keep the floor drain trap primed so I'm confused. |
...Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Here is an illistration for you.
http://www.zurn.com/operations/specd...llation/t1.pdf Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The priming line is a very short distance from the top (usually in a tapped inlet). You can take the top off the drain and see it to confirm. If you really need to, you can shut the water off (normally) to the primer and check to see if it stops running in the drain.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Thanks guys.
| Trap primer valve | dmacy | Plumbing Inspections | 2 | 12/27/06 2:21 PM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 10:57 PM |
| Quick and easy trap question | Danny Castellano | Plumbing Inspections | 4 | 8/14/06 1:17 PM |
| Trap primer | lschmid | Plumbing Inspections | 4 | 4/15/06 12:03 AM |
