Old 12/27/06, 12:29 PM
David C. Macy's Avatar
Default Trap primer valve
Can someone explain how a trap primer valve operates & functions.
This was installed off the cold water line at a 2nd floor water tank.
Thank you
Old 12/27/06, 1:02 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Trap primer valve
When pressure changes in that line (a fixture is used) the trap allows a little water to pass into the trap, keeping it full of water and stopping any sewer gasses that could pass through a dry trap.
Old 12/27/06, 2:21 PM
Tab M. Wilcox Tab M. Wilcox is offline
Please Note: Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
In my area its common to see the laundry floor drain being primed by one of the toilets. When the toilet is flushed water is sent through a check valve and down a pipe (in the slab) to the trap in the floor.
TPR valve acox Plumbing Inspections 19 5/27/07 1:36 PM
Backwater valve in new homes? ccrooker Canadian Inspectors 16 11/28/06 8:47 AM
Trap primer lschmid Plumbing Inspections 4 4/15/06 12:03 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
