Isn't this a great job or what
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
AH HA, There's my slinky!
It's hard to tell, it's vibrating so bad I cant see it.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
It needs duct tape!
Dr. Suess strikes again. boy that cat in the hat is a sneaky fellow at that.
jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
Where's the weir??
If it drains leave it alone.....
I don't see an "S" trap or "unnecessary turns" in your photo Earl. I do see shaving cream which, I assume means that it's a vanity (not a kitchen) sink. and I also assume an older home. It,s not pretty, but I'm not sure how else they could have connected it.
I would probably go with "the sink drain piping appears to be functional (if it was) but you should be aware flex connections can be prone to clogging". |
Thanks guys
There was a huge argument on slinky traps over at inspectionnews.com last year. The Florida boys found tons of code saying slinky traps are not allowed.
We use them here in San Diego, but my own experience with them leads me to put this in my report for my Clients whenever I find a slinky trap: Flexible accordion drain pipes at sink in *****. Maintenance concern. Flexible accordion drain pipes typically are not rigid enough to resist damage on a daily basis in sink cabinet areas and should not be used on a permanent basis. Recommend having standard rigid tailpipe installed to help prevent leaks and water damage. |
On the other hand, I doubt anyone would fault you for calling for repair...it's one of those gray area calls...but just make sure it's for the right reasons. "Assessment by a licensed plumber"? For a readily visible sink trap??? Sorry, but that's a little too much CYA. There may well be different opinions on this particular one, but we should be able to form that opinion ourselves. I don't know how much space is available under the sink, but it looks like the best fix or improvement would be a quick offset on the sink tail piece which would then allow the space for a regular trap without the flex. |
| What type of sink trap is this? PIC. | gromicko | Plumbing Inspections | 36 | 11/12/06 12:04 PM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/15/06 12:00 AM |
