The half bath had an interesting trap that I have not seen. Do you know what type it is?
At the laundry the drain was fixed and it appeared to have a PVC back flow. Is that a trap? If not does it need one? Do stand pipes to fixed drains need traps? Thanks By the way a group named South side Johnny sang a song trapped again. |
If that's a 2" into the slab it could have been roughed-in for a shower with the trap below the slab and later converted for a laundry sink. I haven't seen PVC back-flo devices so that's a new one on me. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Nice!!
Should there be a trap installed? |
Yes You need a trap under that utility tub....
Maybe the owner (or someone) thinks that a spring loaded check will keep gas from coming back through to the laundry tub? Needs a trap. Laundry tubs drain all type of debris (lint, etc.) that will get behind the seal in a check and prohibit it from closing.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Thanks guys.
This is the 1st time I have seen this type of backflow? I did report that there shuold be a trap installed. |
Mike , I have never seen a bottle trap, but my first thought was a drum trap which is not considered sufficient.
Is a bottle trap enough of a water barrier ? |
Bob, the answer is depends but probably no. Up to the AHJ as always.
From one of the manufacturers: Please note that bottle traps (all brands) may not be per code (meaning they may not be legal) in your area. It would be best to check with your local plumbing code before purchasing and installing them. Bottle traps are used in many countries as the "standard" trap but not in the U.S. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Must be a version of a drum trap then.
I get these on many inspections , under tubs and upside down so the tub water hits you in the face when you rod from the basement.. |
It seems clear it is a bottle trap. Drum trap have cleanout access on the bottom side. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Same kind of design is<nt Mike?
Other than the clean out it seems to function the dame. By the way I have seen 100's of drum traps not upside down in apartments , where they are usually placed between the tub and toilet. It is flush mounted to the flloor with a chrome cap. |
DRAWING You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
ah , very interesting.The design is like a regular drain trap internaly.
What is the problem with them? |
| Double Trapped? | jwortham1 | Plumbing Inspections | 11 | 11/9/07 4:39 PM |
| Just when you think you've seen it all | jhugenroth | Inspecting HVAC Systems | 13 | 10/12/07 3:30 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| AC Question | cbellefontaine | Inspecting HVAC Systems | 11 | 12/15/06 3:43 PM |
| Garbage dispoal plug | JohnH515 | Plumbing Inspections | 12 | 3/1/06 9:54 AM |
